I’m not sure whether “EndeavourOS” packages the ChromeOS EC drivers by default; you should be able to discover if it does by checking…
Is there a cros_ec_lpcs.ko under /lib/modules?
`find /lib/modules -name ‘cros_ec*’
Is /dev/cros_ec present?
ls -l /dev/cros_ec
Are the modules throwing any errors?
dmesg | grep cros
LEDs
Unfortunately, yes - both of these things have changed with the AMD framework laptops.
The power LED no longer supports anything but white; it was updated for compatibility with the chromebook edition which only supported white.
I suspect they wanted to keep documentation between the models similar.
The side LEDs are treated as one entity, “charge” or “battery”, in the AMD boards and probably any newer boards as well.
Battery
You can issue a battery disconnect manually with ectool batterycutoff.
The machine is not intended to be used with the battery shut down. Do this only for experimentation.
In addition to what @pierce said (thank you!), I wrote up a quick gist explaining how to take a clean Debian install (I used a container, but you can use bare metal or whatever) to a Zephyr build environment. It’s actually terrible.
I’m getting this error on FW 13 Intel 13th gen, is there any way to fix this? I couldn’t figure it out… Just FYI I’m on BIOS 3.05 (recently released)
❯ sudo ectool chargecontrol
ERROR: Old EC doesn't support GET.
Usage: chargecontrol
Get current settings.
Usage: chargecontrol normal|idle|discharge
Set charge mode (and disable battery sustainer).
Usage: chargecontrol normal <lower> <upper>
Enable battery sustainer. <lower> and <upper> are battery SoC
between which EC tries to keep the battery level.
❯ sudo ectool chargecontrol normal 20 80
ERROR: Old EC doesn't support sustainer.
I just built mainline v6.10 and Dustin’s patches are already present -
commit c8f460d991df
Author: Dustin L. Howett <dustin@howett.net>
Date: Tue Apr 2 19:47:13 2024 -0500
platform/chrome: cros_ec_lpc: add quirks for the Framework Laptop (AMD)
The original Framework Laptop 13 platform (Intel 11th, 12th, and 13th
Generation at this time) uses a Microchip embedded controller in a
standard configuration.
The newer devices in this product line--Framework Laptop 13 and 16 (AMD
Ryzen)--use a NPCX embedded controller. However, they deviate from the
configuration of ChromeOS platforms built with the NPCX EC.
* The MMIO region for EC memory begins at port 0xE00 rather than the
expected 0x900.
cros_ec_lpc's quirks system is used to address this issue.
Signed-off-by: Dustin L. Howett <dustin@howett.net>
Reviewed-by: Thomas Weißschuh <linux@weissschuh.net>
Tested-by: Thomas Weißschuh <linux@weissschuh.net>
Tested-by: Mario Limonciello <superm1@gmail.com>
Link: https://lore.kernel.org/r/20240403004713.130365-5-dustin@howett.net
Signed-off-by: Tzung-Bi Shih <tzungbi@kernel.org>
M drivers/platform/chrome/cros_ec_lpc.c
My FW 16 hibernates and recovers ok with power cable plugged in
But if I then unplug the power and use zoom-client (a snap in debian bookworm) to connect to a meeting it freezes for a about 3-5s then goes black screen and after a while reboots. Strangely the ectool console shows no sign of the reboot that I can see - https://paste.debian.net/1323605/
You need to build it from the source code. [later: I was mistaken. Binaries are available. See @deLemere’s post under this one.] There are links to Dustin’s ectool web pages (for crude instructions) and his git repo in this thread. I’ve not actually built it myself (although I understand the process).
I’ve been following this thread for a couple of years. The tool’s capability, build process and compatibility gotchas are explored in a lot of detail. If you’re thinking of building it yourself, grab a beverage and start reading from the first post.
If you summarise your system (FW model, distro and kernel version) someone who’s built it for a similar system might be willing to help you avoid any of the bumps they found in the road.
Dino
edit: corrected a misunderstanding for future readers.
I apologize if this is already answered in this thread. I tried searching for “flash RW” or “write RW” and came up empty handed. I’d like to build a new version of the lotus EC and write it to my RW slot. My primary interest is fixing the bug where the CPU gets stuck throttled at low MHz after being plugged in and waking. Unfortunately, with the console commands disabled and the read to memmap only taking a single byte means I can’t get a read out of EC_MEMMAP_POWER_SLIDE (0x151). Same issue with enabling safety_pwr_logging since that requires a console command. I figure a custom build can log the right data for my debugging and allow me to hopefully figure out where the bug is that is getting me stuck in a throttled state (or at least allow me to send a command to unstick things).
Is there good documentation as to how to build a local branch and flash it to RW (plus how to get back when it inevitably goes wrong ).
Btw, for anyone wanting to use Github search to find things, I forked the Framework/EmbeddedController repo and made a branch with the current lotus EC code as the default branch. That makes it so searching the repo in Github searches that branch instead of the hx20-hx30 branch. I made a new branch instead of using the lotus-zephyr because I didn’t realize that was already at the correct commit
