Fan is active without reason
My fan has been acting up lately. It keeps turning on and off. When it’s on, it’s very loud. This happens even when it’s cold. It’s on for 5 seconds, off for 3 seconds, on for 10 seconds, off for 7 seconds—there’s no discernible pattern. I cleaned the inside of the unit, but it didn’t help. Could a sensor be broken?
Any suggestions welcome
Framework Laptop 13 DIY Edition (11th Gen Intel® Core™)
(Keyboard: German (1 st Gen), System: Intel® Core™ i5-1135G7)
Linux Mint 22.3 - Cinnamon 64-bit
If you run framework_tool --thermal what does it show?
(Referring to the native Framework tool available here: GitHub - FrameworkComputer/framework-system: Rust libraries and tools to interact with the Framework Computer systems · GitHub)
What BIOS version do you have installed?
Install s-tui and lm-sensors. Then $sudo s-tui you can check the temps, fan RPM and the CPU power
BIOS version is 03.07.
s-tui and lm-sensors do not show anything similar to fan rpm. Temperature is 31 °C.
Finally, I ordered a new fan. The problem disappeared after mounting it.
