I’m using the Framework Laptop 16 7040 series with no GPU, and the CPU heats up to over 90 degrees Celsius whenever I run it at full capacity editing video or converting files in bulk. I think there should be a BIOS option to change the maximum temperature to 90 degrees instead of 100 degrees.
