Has anyone said coffee grinder yet?
What about an expansion that provides an enchanced cooling for the CPU?
For instance it would allow the internal fans spin slower and it could have more and/or other ways to cool the system.
A cooling expansion card.
I donāt know about the performance of the initial one thatās āincluded out of the boxā but what Iām thinking about is about pushing the CPU further while still retaining low temps.
The thing is that cooling is never enough especially in a laptop. So why not make a cooling-focused expansion.
āclassicā docking connector for semi-stationary use at multiple locations. Docking station with lots of connectors as desired (legacy DVI and/or Displayport and/or HDMI for use with existing monitors, ethernet, USB-A, 3,5mm headphone jacks, legacy serial ports, power) and optional active components like graphics cards.
Alternatively, a row of the small expansion slots like the six on the sides of the FW 16, as real estate to the side of the laptop is better used for other things than bulky cables.
EDIT: Thatās for the FW 16 graphics extension bay, not the standard small ones.
I have a customer who has to rely on a 2010 macbook pro because heās a musician and is forced to use firewire. So going back and making all of these old ports accessible would be really cool
What I really really want to see in an expansion slot 1-2 SD-Card readers and at least 1 CFExpress card reader!
When Iām out on a shoot I want to be able to copy multiple audio recorder cards (full size SD cards) and my camera card (CFexpress) onto my laptop. Yes I have my dongles and I hate that everything is a dongle! Someone make this happen plsss ![]()
CFExpress type A cards are similar in shape to SD cards, not sure how different they are electrically.
CFExpress type B cards have a different physical shape.
You have to specify which is desired.
SD Cards usually hang off a USB bus, CFexpress cards are PCI-E AFAIK.
My camera gear uses type B. To be honest, Iām not sure Iāve ever seen a type A in the wild. At least any of my colleagues cameras all also use type B
I think some Sony cameras can use CFEXPRESS type A.
Nikon is supporting Type B.
Not sure about Canon or others.
Mine are Nikons, D500, D850, and Z6.
DVI is huge. Itās like, VGA except not.
That is cool.
I donāt know about CFExpress, but I know lots of cameras use CFast. They are faster than SD cards simply because they have more pins and are larger for more components. I would imagine that they would have transitioned (more or less) given that about a decade have passed since then.
Itās also the same signaling as early gen hdmi without the audio part (for the digital version) and deepfried vga for the somewhat rarer anaolg version.
That capability is already on 5 of your 6 usb-c ports. If you want to add an egpu then just the top 2 but the switch literally just uses just a usb+displayport dock.
I am aware. Iām just curious if somehow more processing power could be added to the equation.
You can hook up an egpu to the top 2 usb-c ports if thatās what you mean, or to the occulink expansion bay (community project) but that one also nees an usb connection for power and peripherals and you canāt hotplug that one.
Iād like to reiterate that the #1 thing Iād like to see developed is a hot-swappable battery expansion bay ![]()
+1 for battery & oculink.
Also, ethernet & cellular that doesnāt poke out the side of the device would be great.
Imagine someone putting a 100gbit nic in an expansion bay just cause itās possible.
An expansion card expansion bay with an internal USB port for dongles, expansion card slots, and ideally flush Ethernet (although the flush Ethernet would result in other issues).
This could be mostly accomplished by creating new internals for the existing expansion bay shell (which is designed to have the internals swapped to have other features such as external I/O).
Unfortunately the expansion bay shell only supports I/O up to 8.65 mm tall, just barely not enough for Ethernet. Furthermore it would not provide easy access to quickly swap expansion cards without opening up the laptop (although given that there are 6 other easily hot swappable card slots I donāt think these 3 necessarily need to be).
So to execute this idea perfectly would likely require a whole new outer shell, which would increase development costs and break compatibility with the existing shell.
Giving up on flush ethernet and easy hotswap I think that 3 expansion card slots could be put on the back of an expansion bay module pretty easily, leaving just enough room to squeeze in an internal USB port for a dongle. That is especially great considering that 4 port supporting 4 ports is pretty much the stands for USB controllers so there wouldnāt even be something non-standard needed there.
The IO port shield is 8.65mm tall, but you wonāt be able to cut such a large hole in it without splitting it. Though the the internal height above the PCB is the limiting factor much sooner.
You have (assuming a 1.2mm PCB), 5mm above, and only in the middle, 1.4mm below.
I donāt think you can get a USB-A port that is smaller than 5.7mm, and unless you find (or bent into shape) one that only puts ~1mm below the PCB surface, you wonāt fit a USB-A port on the board edge, if their measurements are exact. Maybe with the shell in hand you can find a spot.
However, you can easily get an internal port to work in the middle area, again using a thin sink-PCB port like the U234-091N-4BLT03-F5, where you have 1.4+1.2+5 = 7.6mm to work with.
However, I wouldnāt bet on too many dongles to fit that, especially since Iām not sure how vertically centered it would end up being.
Thunderbolt-PCIe bridge solutions exist but are quite expensive. I suggested for PCIe breakouts in the form of SFF8643 (Oculink) connectors. You can then design whatever cursed creation you have on your mind with said PCIex8 link. A PCIe mux (not that expensive, if you donāt mind going 1/2 gen down), add external power, and you are basically good to go.
This is in my original post, as well.
mid-mount (in-PCB) USB-A ports exist.
But my question is why many people so want to make dongle hiders.
You can achieve that by ⦠making recessed connectors. Even a mild 3mm/5mm recess would eliminate enough of the protrusion from like a Logitech dongle to basically be a non-issue.
Furthermore, the expansion bay is, unlike expansion cards, not constraigned by the height of the machine. You can have the expansion bay stick out the bottom of the laptop. And since itās a large part of the laptop, it have enough strength to hold up (the laptop), among others. Sort of like the extended battery packs of the old.
A lot of the ideas are repeated in the first few posts of the thread. It would help if somehow a poll can be made (e.g. Microsoft forms), and someone to organize that data into general categories.
Maybe me. But I donāt work for framework. I donāt need to trouble myself with this. Itās cool, but I donāt even own a Framework 16 yet. Still waiting on their Intel versions and/or DDR4 boards.
