Feature Request Megathread - Expansion Bay modules
When I first trained for this job, one of the things I was repeatedly told was that the CPU would almost certainly be the last component to be at fault. For the most part that was true - I very rarely replaced processors, and only after… well, pretty much everything else. In the days before soldered CPUs that meant laptops didn’t usually get new ones either.
A few years back, it seemed like I was replacing about one or two a month - an unheard of frequency IME - and always with a similar pattern: multiple bluescreens with random titles, successful diagnostic test results, and no other explanation. The mainboard, RAM, drive, OS - everything - would be replaced to no avail. But pop in a new proc and suddenly everything was fine.
It’s since died down, although since nearly all of the laptop motherboards I replace now have a soldered CPU, and occasionally that pattern pops up, I sometimes wonder…
I created (completely in my head - not for human consumption) a conspiracy theory to explain it:
To counter the CPU hardware bugs discovered back then (Spectre and Meltdown, I believe?), the industry conspired to send out BIOS updates that would fatally fault the processor, forcing an upgrade - one way or another (for example, on-site repair).
Just something to keep my mind occupied while I ran the diagnostic after replacing the processor I was told I’d never have to replace… :grinning:
Just a note, there is no requirement for posting ideas here, this is a user forum, so it is totally okay to post ideas like these that you have. I agree that it seems like a good concept, but others have brought up concerns about height, and I will also add that Intel (and now AMD) do help Framework design the mainboards, and likely have guidelines that will not permit them to put processors on separate boards, as they don’t want lost performance from that to seem like a fault of the chips themselves (this is speculation though)
I’d personally love to see an idea like this since I also want an easier way to replace the CPU and also a potential for adding a CM4 powered Framework, but it’s also important to remember that Framework likely thought of a lot of things like this on their own, and that some/all of the constraints mentioned could be the reason why they weren’t able to implement it.
Removable CPUs aren’t unprecedented in laptops, hell I saw a video on one where the guy upgraded the GPU, CPU, RAM, and Storage in one go. Even managed to get SLI over Mini-PCIE Modules (MXM dGPU’s) Framework 16 comes closer in that respect.
But I would really love it if the CPU Socket/Chipset were on a separate daughterboard. More so if the CPU itself was replaceable. At the minor expense of a bit chonkier laptop due to adjusting how the cooler mounts on, or even minor & theoretical performance differences.
If we’re keeping the rest of the board separate, let’s say someone wanted a 10th Gen Intel Framework for whatever reason… :eyes: Then they could downgrade the UEFI, swap out the 11th Gen Daughter-board and try it out as a troubleshooting test or experimental project. Similarly if they wanted to try a different CPU in the same family/socket or dare I say an upgrade that supports the same socket.
Now ofcourse I know this won’t mean we can suddenly change an Intel board to an AMD one due to universal firmware not really being a thing here, but I can see interesting use cases for it already. The raspberry pi of laptops
Exactly! I am glad to see there are other people that are on board with this idea! Maybe, if it gets enough traction here, it might be noticed by the framework team, and potentially implemented in a new updated version of the mainboard! Also, this dream may be getting closer to reality as we speak! In a not-so-recent-as-of-recently video from Linus Tech Tips, where they were reviewing a new mini-PC from a company called: minisforum, I saw Jake put a laptop CPU into a real-freakin-small socket in the devices motherboard! So, these manufacturers might already be bringing socketed mobile chips back, which is amazing!
The framework 13 mainboard already kind of is a cpu daughter-board, you can’t strip it down a lot more and only at the cost of a lot more complexity which for most cases is not worth it.
Would be neat if they could expose some of the unused io on the cpu though but I can also understand why they didn’t do that.
I remember the old Clevo desktop replacement laptops could drop in a lower TDP desktop CPU in. If my memory serves, the earlier generations there were socketable laptop CPUs too.
Maybe the 16 inch could potentially have enough Z height but that would really make it thick/bulky (which is not the trend nowadays).
Another issue would be the pinout of different generations (see Intel) is probably different, so might break compatibility too, else the R&D process would really take a long time.
Being able to use a CM4 would be very interesting.
There are multiple different CM4-compatible modules available, from rpi, rockchip, nxp as well as riscv and fpga options.
My idea would not be to replace the internal CPU, but being able to use a different architecture with the same screen and keyboard and seamless switching between them.
This would require a HDMI to display port IC some means to expose USB devices to the CM4 socket.
If USB and HDMI are exposed as well on ports on the back, this daughter board could also be used as an external monitor/keyboard for servers or anything else.
I was searching for a laptop stand for my framework 16 (no, I haven’t received yet, I’m batch 15), and though: what about retractable foots as an expansion bay?
Like many keyboards have small foldable “foots”, I think of “long” (~20cm) legs, one for both sides, allowing the laptop to “stand” with the screen nicely raised at eye level.
I’ve considered designing legs that could be installed in the expansion card slots but I can’t think of any good designs that won’t be too wide when folded away yet stable enough when extended. I think it’s more than possible, though.
Maybe they could be “folded” under the laptop, hidden near the small riser foot already installed on the underside of the dGPU module? This way it won’t stick out more than the module already does.
Don’t give me any ideas… Ha ha!
Ok, this might be incredibly stupid, but hear me out…
A small i3 or Pentium computer in the expansion bay that can be controlled with a built-in KVM. It could be a little development environment for testing apps, kernel drivers, researching malware, or whatever you want. Would a VM probably work better?? Yeah, but that’s not as cool.
On a serious note, it could be very useful for developers working on risc5 support because all the risk5 boards available aren’t bigger than an RPI anyway. Just slap one in there with a KVM and maybe some debugging hardware. It would provide a way to run code on risc5 hardware directly while leveraging your normal laptop to run your heavy development environment and other apps (Spotify, Google, Discord, Teams, etc). Then use the debugging hardware to flash and run the code on the risc5 board when you want to test.
Make your own RISC-V board with the new PIC64 chip from Microchip. Contains a quad core RISC-V processor plus a superviser core (If I am reading the info correctly). Has multiple PCIe channels and uses external DDR4 memory.
It was more of a fun idea. If something comes of it, great! If not, I wasn’t expecting anyone to design this for me. I am going into my second year of college studying to be an Embedded Engineer, so while I don’t have the knowledge to design this idea now, I totally would be down to designing it sometime after I graduate. I think it would be really fun and it’s the type of thing I want to be able to do for a living.
U.2 carrier card. Maybe sata.
It fits (?), although for u.2 cooling is going to be a colossal issue.
Hello
I have a suggestion for the framework 16 to add rear ports module to the expansion bays.
Especially the Graphic expansion bay.
More ports is necessary and also rear ports help to free space around laptop.
Personally I like to see HDMI, lan, power that are commonly connected at the back of the laptop to free the space around me.
If you have seen thieir blog (I think), they tried to fit something other than a Type-C at the back, but the gigantic heatpipes blocked everything else.
But now you mentioned it. I think a PCIe dock would … I mean its basically a thunderbolt dock by that point. But it will be a cheaper solution. To have loads of ports.
Maybe have it be an expansion bay shell config, not a GPU module config, as the shell is pretty empty. Unless you want to make the GPU module unpractically large. The 16 is already very deep as-is, barely fit in my bag.
I miss the days you can just plonk your laptop onto a dock and have like, 4 more USB, multiple displays, and optical. Thunderbolt dock still exist and are more universal, but are rather expensive and frankly the expansion option is somewhat limited.
A 4 or 6-port SATA expansion board would be nice. With a 3D printed custom case, one can create a nice and cheap home server / NAS device.
I would really like to see a water cooled dGPU expansion module with an attachable external water cooling solution. (Similar like the XMG Neo from Schenker with the XMG Oasis)
Because this would totally solve the problem with loud fans and overheating laptops when they are stationary used as a workstation. eg for AI workloads. The only limitation a laptop has is cooling, this solution is a proposal to fix it while its stationary at home.
https://www.xmg.gg/en/xmg-oasis/ they did it already. But i would like to see this opensource with swapable GPU’s, also AMD based ones.
I know there have been a number of fpga topics and suggestions, but hear me out…
The MISTer project has a large community dedicated to preserving arcade and retro gaming hardware in the form of fpga cores that are designed to run on the DE10 nano, a common fpga development board.
I would love to see something like this integrated into the expansion bay module which could run the MISTer cores and be operable using the laptop. Even better would be if there was keyboard and monitor passthrough so the fpga output could be shown on screen.
Personally I don’t know enough about the technical challenges to know how feasible this would be, but there are pre-existing raspberry pi integrations out there which have similar functionality, and use slightly different hardware.
Anyway, there’s some food for thought.
