The AMD Radeon 890M drivers are a bit buggy at times. This turns off some of the power saving features that have issues. In X11, this will happen all the time. Wayland not nearly as much.
Try this:
sudo nano /etc/default/grub
GRUB_CMDLINE_LINUX=“quiet splash” Find this line, leave all additional parameters intact and change it to:
GRUB_CMDLINE_LINUX=“quiet splash amdgpu.dcdebugmask=0x410”
Sadly that change didn’t make a difference. Just froze on updateing kernel modules again.
Is maybe turning off hybrid graphics required?
Running the update firmware commands provided from Framework, it does not update anything and shows the ones it knows about are already up to date and there a number of entries that it does not have information for.
