Fedora 44 KDE issues on Framework 16
Hi,
I’ve got a gen 2 FW16 with the AI 9 HX 370 and RTX 5070.
It ran flawlessly Fedora 43 KDE but after upgrading to 44 it wouldn’t recognise my keyboard, fingerprint scanner, and removeable media. External input devices were not recognised either.
Trying Fedora 44 on a live USB also did not work - plasmahell and kwin crashes immediately upon boot followed by black screen.
Additional info - lates BIOS, latest kernel.
Any ideas?
Unfortunately no idea how to fix it, but bumping as I’m also having this issue. I have however narrowed it down to being an issue with KDE, likely due to wayland, because Fedora 44 Gnome works flawlessly for me.
It’s definitely something to do with KDE and Wayland.
I hadn’t done any updates in a while so my first thought was something to do with the new 7.0 kernel, but it’s not that as the same kernel works fine with F43.
Then I thought it may be something with sddm but even with that switched off it still doesn’t work.
TTY session prior to logging into a graphical environment works perfectly fine. libinput debug-events works fine in TTY - no issues noted. Everything is great until you try to log into a Wayland session and then it’s no longer fine.
I spent a good few hours trying to debug it but can’t pinpoint the exact root cause.
FYI, Original FW16 here (AMD 7840 – batch 6? I think) and did the move to F44 close to 2 months back (I think it was 5/13).
and so far things are working fine.
(system started as F39, then ->F40->F41->F42->F44)
running KDE Plasma spin.
I’ll have to verify removeable media tomorrow, but typing on the built-in keyboard, fprint reader working fine (well no changes from earlier fedoras – I have the occasional on laptop wake up it doesn’t like the scanner at first – but subsequent unlocks, uses of fprint work fine – issue), etc.
I do have these graphics flags from way back still in my kernel args;
“amdgpu.dcdebugmask=0x410 amdgpu.sg_display=0”
(been meaning to make time to try removing them and seeing if the werid issues come back – was for an older kernel in F41 era I think)
so different motherboard/CPU, but may be something specific to that?
I did notice today (while looking for a forum query someone had on FW desktop on which fedora version) that FW still has F43 as the listed version:
I have the exact same model of the Framework 16 as you, which I received last week. I started with Bazzite and am thinking about switching to Fedora 44 KDE now as I’m having a lot of problems with Bazzite (which is really unfortunate as I like some of its additions) like mic not working at all, WiFi problems etc., and Fedora 44 KDE is the distro/DE I have on my other machines.
Do you have any updates on your problems? I didn’t do the switch yet but I tried a live session and I didn’t have the problems you describe, the session boots normally and is usable (even had the mic working. But it seemed very unstable and some applications crashed or didn’t work as expected, like pre-installed Firefox not launching at all. I’m curious if it’s a real compatibility problem of the Framework 16 with the AI 9 HX 370 CPU, or if it’s just the live session and the problem goes away after installing and updating the system.
Anyway, would like to get an update on your problem, hope it solves.
If it’s working mostly on the live system I reckon it’ll be absolutely fine on proper install. Give it a go.
I haven’t tried it again. I’ll just wait for Fedora 45 and have a play again. I don’t have much time lately to mess around so I’m prioritising a working stable setup for now.
Not completely true. These LiceCDs especially Fedoras are not updated after release so they use older kernel, older packages than fully updated systems.
Wouldn’t be the first time where livecd boots and works fine and after first boot and update something breaks.
Identified the issue. It was the UAS driver on the 250GB Expansion Card. It was throwing errors basically failing the entire USB controller and everything that runs off it. Changing the driver from UAS to usb-storage fixed the issue.
