Hi, are you still having the same issues on Fedora? I have what seems to be equivalent issues connecting to eduroam on my university (so WPA2 enterprise connections) on Arch Linux running the latest 6.18 kernel. I’ve now reverted to using the LTS kernel instead of the latest kernel, but it has been an annoying bug since I can’t find any useable information on it in the journal. My logs:
dmesg:
[ 4.807427] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.922239] mt7921e 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.922439] mt7921e 0000:01:00.0: disabling ASPM L1
[ 4.926791] mt7921e 0000:01:00.0: ASIC revision: 79220010
[ 5.001389] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20260106153416a
[ 5.016904] mt7921e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20260106153507
[ 6.139687] mt7921e 0000:01:00.0 wlp1s0: renamed from wlan0
[ 7.100898] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 17.217658] wlp1s0: authenticate with [EDUROAM-MAC] (local address=LOCAL-MAC)
[ 17.697089] wlp1s0: send auth to [EDUROAM-MAC] (try 1/3)
[ 17.721018] wlp1s0: authenticated
[ 17.721449] wlp1s0: associate with [EDUROAM-MAC] (try 1/3)
[ 17.736212] wlp1s0: RX AssocResp from [EDUROAM-MAC] (capab=0x11 status=0 aid=49)
[ 17.766047] wlp1s0: associated
[ 18.025498] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by [EDUROAM-MAC]
[ 42.001990] wlp1s0: deauthenticating from [EDUROAM-MAC] by local choice (Reason: 3=DEAUTH_LEAVING)
[ 45.322515] wlp1s0: authenticate with [EDUROAM-MAC] (local address=LOCAL-MAC)
[ 45.336988] wlp1s0: send auth to [EDUROAM-MAC] (try 1/3)
[ 45.339682] wlp1s0: authenticated
[ 45.340526] wlp1s0: associate with [EDUROAM-MAC] (try 1/3)
[ 45.354376] wlp1s0: RX AssocResp from [EDUROAM-MAC] (capab=0x11 status=0 aid=147)
[ 45.382598] wlp1s0: associated
[ 45.465545] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by [EDUROAM-MAC]
[ 67.002254] wlp1s0: deauthenticating from [EDUROAM-MAC] by local choice (Reason: 3=DEAUTH_LEAVING)
[ 70.304571] wlp1s0: authenticate with [EDUROAM-MAC] (local address=LOCAL-MAC)
[ 70.318447] wlp1s0: send auth to [EDUROAM-MAC] (try 1/3)
[ 70.375768] wlp1s0: authenticated
[ 70.377439] wlp1s0: associate with [EDUROAM-MAC] (try 1/3)
[ 70.423643] wlp1s0: RX AssocResp from [EDUROAM-MAC] (capab=0x11 status=0 aid=154)
[ 70.453438] wlp1s0: associated
[ 70.453494] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by [EDUROAM-MAC]
[ 92.002330] wlp1s0: deauthenticating from [EDUROAM-MAC] by local choice (Reason: 3=DEAUTH_LEAVING)
NetworkManager journal:
feb 27 12:26:46 ez-2-arch systemd[1]: Starting Network Manager...
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2839] NetworkManager (version 1.54.3-1) is starting... (boot:645a5e5e-7f09-47ca-a741-c6e58c4eea46)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2840] Read config: /etc/NetworkManager/NetworkManager.conf, /usr/lib/NetworkManager/conf.d/20-connectivity.conf
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2892] manager[0x55b151d16110]: monitoring kernel firmware directory '/lib/firmware'.
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2900] hostname: hostname: using hostnamed
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2900] hostname: static hostname changed from (none) to "ez-2-arch"
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2902] dns-mgr: init: dns=default,systemd-resolved rc-manager=symlink
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2914] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:02.2/0000:01:00.0/ieee80211/phy0/rfkill1) (driver mt7921e)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2917] manager[0x55b151d16110]: rfkill: Wi-Fi hardware radio set enabled
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2917] manager[0x55b151d16110]: rfkill: WWAN hardware radio set enabled
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2941] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-adsl.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2972] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-bluetooth.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.2977] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-ovs.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3165] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-team.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3174] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wifi.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3179] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.54.3-1/libnm-device-plugin-wwan.so)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3181] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3182] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3182] manager: Networking is enabled by state file
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3188] settings: Loaded settings plugin: keyfile (internal)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3212] dhcp: init: Using DHCP client 'internal'
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3213] manager: (lo): new Loopback device (/org/freedesktop/NetworkManager/Devices/1)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3217] device (lo): state change: unmanaged -> unavailable (reason 'connection-assumed', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3218] device (lo): state change: unavailable -> disconnected (reason 'connection-assumed', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3220] device (lo): Activation: starting connection 'lo' (8deb502d-7b87-4652-85de-f81094da702e)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3227] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3230] settings: (eth0): created default wired connection 'Wired connection 1'
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3230] device (eth0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3236] device (wlp1s0): driver supports Access Point (AP) mode
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3238] manager: (wlp1s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.3239] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9137] device (wlp1s0): set-hw-addr: set MAC address to 8E:17:2A:F1:03:D3 (scanning)
feb 27 12:26:46 ez-2-arch systemd[1]: Started Network Manager.
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9781] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9792] ovsdb: disconnected from ovsdb
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9793] device (lo): state change: disconnected -> prepare (reason 'none', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9794] device (lo): state change: prepare -> config (reason 'none', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9795] device (lo): state change: config -> ip-config (reason 'none', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9799] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9806] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
feb 27 12:26:46 ez-2-arch NetworkManager[908]: <info> [1772191606.9807] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0170] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0171] Wi-Fi P2P device controlled by interface wlp1s0 created
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0172] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0173] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <warn> [1772191607.0174] device (p2p-dev-wlp1s0): error setting IPv4 forwarding to '0': Success
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0175] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
feb 27 12:26:47 ez-2-arch NetworkManager[908]: <info> [1772191607.0177] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.0217] device (wlp1s0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.0217] device (wlp1s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.0322] device (wlp1s0): supplicant interface state: interface_disabled -> inactive
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.0322] device (p2p-dev-wlp1s0): supplicant management interface state: interface_disabled -> inactive
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1686] device (wlp1s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1687] device (wlp1s0): state change: prepare -> config (reason 'none', managed-type: 'full')
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] device (wlp1s0): Activation: (wifi) connection 'eduroam' has security, and secrets exist. No new secrets needed.
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'ssid' value 'eduroam'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'scan_ssid' value '1'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'bgscan' value 'simple:30:-65:300'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'proto' value 'RSN'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'pairwise' value 'CCMP'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'group' value 'CCMP TKIP'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'password' value '<hidden>'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'eap' value 'PEAP'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'fragment_size' value '1266'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'phase2' value 'auth=MSCHAPV2'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'ca_cert' value 'blob://[CAT-tool inserted cert]'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'altsubject_match' value 'DNS:radius.[university]'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1688] Config: added 'identity' value '[redacted]@[university]'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.1689] Config: added 'proactive_key_caching' value '1'
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7050] device (wlp1s0): supplicant interface state: inactive -> authenticating
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7051] device (p2p-dev-wlp1s0): supplicant management interface state: inactive -> authenticating
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7290] device (wlp1s0): supplicant interface state: authenticating -> associating
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7290] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7788] device (wlp1s0): supplicant interface state: associating -> associated
feb 27 12:26:57 ez-2-arch NetworkManager[908]: <info> [1772191617.7789] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
feb 27 12:26:58 ez-2-arch NetworkManager[908]: <info> [1772191618.9877] audit: op="statistics" interface="eth0" ifindex=2 args="500" pid=2443 uid=1000 result="success"
feb 27 12:26:58 ez-2-arch NetworkManager[908]: <info> [1772191618.9914] audit: op="statistics" interface="wlp1s0" ifindex=3 args="500" pid=2443 uid=1000 result="success"
feb 27 12:26:59 ez-2-arch NetworkManager[908]: <info> [1772191619.0140] audit: op="statistics" interface="wlp1s0" ifindex=3 args="500" pid=2443 uid=1000 result="success"
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <warn> [1772191642.0091] device (wlp1s0): Activation: (wifi) association took too long
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0091] device (wlp1s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <warn> [1772191642.0093] device (wlp1s0): Activation: (wifi) asking for new secrets
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0151] device (wlp1s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0151] device (wlp1s0): state change: prepare -> config (reason 'none', managed-type: 'full')
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0152] device (wlp1s0): Activation: (wifi) connection 'eduroam' has security, and secrets exist. No new secrets needed.
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'ssid' value 'eduroam'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'scan_ssid' value '1'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'bgscan' value 'simple:30:-65:300'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'proto' value 'RSN'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'pairwise' value 'CCMP'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'group' value 'CCMP TKIP'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'password' value '<hidden>'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'eap' value 'PEAP'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'fragment_size' value '1266'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'phase2' value 'auth=MSCHAPV2'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'ca_cert' value 'blob://[CAT-tool inserted cert]'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'altsubject_match' value 'DNS:radius.[university]'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'identity' value '[redacted]@[university]'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.0153] Config: added 'proactive_key_caching' value '1'
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.1143] device (wlp1s0): supplicant interface state: associated -> disconnected
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.1144] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> disconnected
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.1209] device (wlp1s0): supplicant interface state: disconnected -> scanning
feb 27 12:27:22 ez-2-arch NetworkManager[908]: <info> [1772191642.1209] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3448] device (wlp1s0): supplicant interface state: scanning -> authenticating
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3449] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3473] device (wlp1s0): supplicant interface state: authenticating -> associating
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3473] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3954] device (wlp1s0): supplicant interface state: associating -> associated
feb 27 12:27:25 ez-2-arch NetworkManager[908]: <info> [1772191645.3954] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <warn> [1772191667.0094] device (wlp1s0): Activation: (wifi) association took too long
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0094] device (wlp1s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <warn> [1772191667.0097] device (wlp1s0): Activation: (wifi) asking for new secrets
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0148] device (wlp1s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0149] device (wlp1s0): state change: prepare -> config (reason 'none', managed-type: 'full')
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] device (wlp1s0): Activation: (wifi) connection 'eduroam' has security, and secrets exist. No new secrets needed.
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'ssid' value 'eduroam'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'scan_ssid' value '1'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'bgscan' value 'simple:30:-65:300'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'key_mgmt' value 'WPA-EAP FT-EAP FT-EAP-SHA384 WPA-EAP-SHA256'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'proto' value 'RSN'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'pairwise' value 'CCMP'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'group' value 'CCMP TKIP'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'password' value '<hidden>'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0151] Config: added 'eap' value 'PEAP'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'fragment_size' value '1266'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'phase2' value 'auth=MSCHAPV2'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'ca_cert' value 'blob://[CAT-tool inserted cert]'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'altsubject_match' value 'DNS:radius.[university]'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'identity' value '[redacted]@[university]'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.0152] Config: added 'proactive_key_caching' value '1'
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.1109] device (wlp1s0): supplicant interface state: associated -> disconnected
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.1109] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> disconnected
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.1171] device (wlp1s0): supplicant interface state: disconnected -> scanning
feb 27 12:27:47 ez-2-arch NetworkManager[908]: <info> [1772191667.1171] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.3262] device (wlp1s0): supplicant interface state: scanning -> authenticating
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.3262] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.3837] device (wlp1s0): supplicant interface state: authenticating -> associating
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.3837] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.4664] device (wlp1s0): supplicant interface state: associating -> associated
feb 27 12:27:50 ez-2-arch NetworkManager[908]: <info> [1772191670.4664] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <warn> [1772191692.0094] device (wlp1s0): Activation: (wifi) association took too long
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.0095] device (wlp1s0): state change: config -> failed (reason 'no-secrets', managed-type: 'full')
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.0096] manager: NetworkManager state is now CONNECTED_LOCAL
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.1311] device (wlp1s0): set-hw-addr: set MAC address to 7E:62:C8:28:6B:65 (scanning)
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <warn> [1772191692.1537] device (wlp1s0): Activation: failed for connection 'eduroam'
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.1539] device (wlp1s0): supplicant interface state: associated -> disconnected
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.1539] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> disconnected
feb 27 12:28:12 ez-2-arch NetworkManager[908]: <info> [1772191692.1541] device (wlp1s0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
wpa_supplicant journal:
feb 27 12:26:45 ez-2-arch wpa_supplicant[812]: Successfully initialized wpa_supplicant
feb 27 12:26:57 ez-2-arch wpa_supplicant[812]: wlp1s0: SME: Trying to authenticate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:26:57 ez-2-arch wpa_supplicant[812]: wlp1s0: Trying to associate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:26:57 ez-2-arch wpa_supplicant[812]: wlp1s0: Associated with [EDUROAM-MAC]
feb 27 12:26:57 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-EAP-STARTED EAP authentication started
feb 27 12:26:57 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
feb 27 12:27:22 ez-2-arch wpa_supplicant[812]: nl80211: send_event_marker failed: Source based routing not supported
feb 27 12:27:22 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=[EDUROAM-MAC] reason=3 locally_generated=1
feb 27 12:27:22 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
feb 27 12:27:25 ez-2-arch wpa_supplicant[812]: wlp1s0: SME: Trying to authenticate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:27:25 ez-2-arch wpa_supplicant[812]: wlp1s0: Trying to associate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:27:25 ez-2-arch wpa_supplicant[812]: wlp1s0: Associated with [EDUROAM-MAC]
feb 27 12:27:25 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-EAP-STARTED EAP authentication started
feb 27 12:27:25 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
feb 27 12:27:47 ez-2-arch wpa_supplicant[812]: nl80211: send_event_marker failed: Source based routing not supported
feb 27 12:27:47 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=[EDUROAM-MAC] reason=3 locally_generated=1
feb 27 12:27:47 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
feb 27 12:27:50 ez-2-arch wpa_supplicant[812]: wlp1s0: SME: Trying to authenticate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:27:50 ez-2-arch wpa_supplicant[812]: wlp1s0: Trying to associate with [EDUROAM-MAC] (SSID='eduroam' freq=5180 MHz)
feb 27 12:27:50 ez-2-arch wpa_supplicant[812]: wlp1s0: Associated with [EDUROAM-MAC]
feb 27 12:27:50 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-EAP-STARTED EAP authentication started
feb 27 12:27:50 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
feb 27 12:28:12 ez-2-arch wpa_supplicant[812]: nl80211: send_event_marker failed: Source based routing not supported
feb 27 12:28:12 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=[EDUROAM-MAC] reason=3 locally_generated=1
feb 27 12:28:12 ez-2-arch wpa_supplicant[812]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
feb 27 12:28:12 ez-2-arch wpa_supplicant[812]: nl80211: Was expecting local deauth but got another disconnect event first
