Curious if anyone might be able to point me in the right direction here. I’ve got Fedora 35 installed (on my expansion card, with Win10 on the NVME, not that that should matter), and when I get to the login screen I have the following two minor complaints:
Tapping to click on the trackpad doesn’t do anything—I have to press to click
The display is oversized (like it’s at 200% scaling or something)
Once I log in, everything is fine. Tapping works properly and the scaling is right. For #1, is there any way to enable tap to click before login? And for #2, is there a way to adjust scaling for the login elements, or is that just how it is?
Thanks!
