I just updated to Fedora 42, hoping it would help. But I’m not sure how to update the kernel. I obviously have a messed up system. It has not crashed on me, though. I’ve been able to use it as needed other than the fingerprint issue.
Here is what i get with fprintd-delete
melaniecarr@melanie-fedora:~$ fprintd-delete --help
Usage:
fprintd-delete [OPTION…] Delete fingerprints
<username> [-f finger-name [usernames [-f finger-name ]...]
Help Options:
-h, --help Show help options
The fingerprint is not recognized more times than it is. Not sure what changed that it wouldn’t be recognized more often. It’s just rare that it IS recognized.
I don’t know if it helps at all, but if you register a fingerprint in Linux, and then switch to Windows, Windows cannot use the fingerprint you used in Linux, and you have a register it again for windows. And visa-versa. If you registered in on Windows, it won’t work on Linux.
If you want both, you have to register your finger prints twice, once in Windows and once in Linux.
Thanks. That’s not the case for me. I prefer Linux. Of course now it seems to be working fine once I’m logged into my computer. I don’t get it, but meh.
Before doing anything more, I suggest you create a backup of your system if you know how to, and definitely of your documents
What’s the output of dnf repolist --enabled?
And what happens if you try to run dnf up kernel?
