Fingerprint sensor not detected (Fedora 44, Framework 13 AMD)
Hello there,
so my fingerprint sensor stopped working. It used to work just fine, and the power button is still working and lighting up.
System details:
  • Framework Laptop 13, AMD Ryzen 5 7640U
  • BIOS version: 03.20
  • Fedora 44 (Workstation Edition) with kernel 7.2.11-200.fc44.x86_64
I already tried:
$ lsusb
Bus 001 Device 002: ID 0e8d:e616 MediaTek Inc. Wireless_Device
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 32ac:0002 Framework HDMI Expansion Card
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
$ sudo fprintd-list sam
No devices available
$ fwupdmgr get-devices
No fingerprint device shows up here either — I won't post the whole output, since it's quite long.
What I’ve checked so far:
  • I checked whether the cables came loose — twice.
  • I tried a live Ubuntu image, but the sensor doesn’t show up there either.
If the fingerprint sensor is simply broken, it seems really weird to me that the power button still works fine, since they’re part of the same assembly.
Any help is much appreciated, thanks!
Felix
The sensor might be stuck in a state where it is not working right. A reset of the reader might be in order. Contact support for the best approach to get it cleared up. It happens with these readers sometimes.
