Firmware Downloads site down?
I’ve been looking for the download for BIOS version 3.07 for Intel® Core™ Ultra Series 1 as I need to update manually, but the URL seems to be 404’ing. Is anyone else having the same issue?
https://downloads.frame.work/bios/Framework_Laptop_13_Intel_Core_Ultra_Series1_BIOS_3.07_EFI.zip
Seems to also be affecting older versions and other laptop configs:
https://downloads.frame.work/bios/Framework_Laptop_13_Intel_Core_Ultra_S3_BIOS_EFI.zip
Windows downloads are unaffected.
@Eagle it looks like all BIOSes in EFI version cannot be downloaded. Can someone from framework team check it?
Windows exe files can be downloaded but EFI version link are broken for any laptop version
thanks for flagging, looking into this now!
this should now be fixed, let us know if you run into any other issues accessing the files! thanks again for flagging this
Thanks, I’m able to download them again!
