Which Framework product: First batch Framework 13 - upgraded to Intel 13th gen
I’ve had an issue pop up recently where the internal mic cuts out sporadically in the middle of calls. Confirmed that it’s not application specific, happens in all apps. I can sometimes fix this by toggling the hardware cutoff switch, but that is working less reliably now. I’ve taken out the module and reseated the cable.
Just another user like the OP here. It could be the cable or the webcam module itself. Not a lot of discussion of either of those going out, maybe order the new webcam module and the cable?
If it is not the cable then a solder joint or component may be failing in the original module. Frustrating I know, at least it is a fairly inexpensive fix and easily repaired.
