Thanks but I love using KDE to much to change!
I’m guessing Google’s Chrome operating system, ChromiumOS, is out of the question then. ![]()
I would usually take desktop hopping over distro hopping any day now, but I’m trying to relearn Fedora for the first time in 10 years, alongside Windows which I haven’t touched in over 20 years. Doing it all on this Framework Laptop 12… can’t say much has changed at microcoughed, I still get frustrated fixing it for them, when I paid them!? lol I’m currently doing Fedora with Windows and Plasma( though I did eat PB&J for a month because I got the 32 GB of RAM).
Here is from my settings in case it helps:
otherwise, maybe look into the browser’s web store, extensions, and the like?
We could also modify KDE or Fedora quite a bit, though I’m sure that is the primary purpose of many of those spin-off desktops in this case.
Hopefully, you only got one stick of RAM so you can upgrade later. I’ve got a deposit in for the Core motherboard to upgrade mine now.
Edit: sorry, we’re talking about the 13 so you might not be able to do two sticks depending? I have a Framework 12, so 1xDDR5 SO-DIMM ![]()
Hi,
Yea I love the Fedora KDE combo a lot and think im going to stick with it.
Im looking into this atm
I got a F13P so only one slot but it would also cost all my arms and legs if I wanted to get 32 in the next year or so at least.
Thanks!
Hi,
I have received my laptop and here is my RAM usage it constantly hovers around 85-95% with these apps open with Auto Tab Discard: @Squiggler
It still seems to be running slow even just typing this reply the letters are a few seconds delayed from input. Dont know if this is just Fedora KDE or if something is wrong?
Hmm, you have three apps that have a heavy disk read load: Grayjay, Steam, and SyncThingy, and Proton and Background Services are not as bad, but they’re still using it a lot.
Grayjay is taking 1.7GB of RAM, which is more than a little, but Chrome’s usage is low for a browser. Thus, for a 16GB machine, RAM isn’t the problem here. I think your apps are making a lot of disk read requests, and their progress (on whatever they are doing) is backing up in a queue.
Have a look at your disk read/write and swapfile usage over time too - your process monitor should have a pressure/time line graph. If it is this bad consistently, it’s no wonder it is sluggish.
Without Grayjay im sitting around 77% at 11.5GB used here is what system monitor is saying:
Seems that the Storage is not being hit hard?
OK, that first snapshot is significantly better. There is still RAM to spare, and disk reads are not maxing your system out. Is it now much more responsive?
I suspect Background Services is a shared process, so when Grayjay misbehaves, the impact will be reported here too.
what is this “background services” anyway? it is taking up 750MB of memory
I want to say its lumped system/kernel tasks, but linux tend to not do that. idk.
I use gnome, and gnome task manager just show you the whole list.
I’m a ‘tab hog’ too… but I don’t think I’ve ever hit in the 100s on Chrome. Chrome is a notorious memory hog, but… alas… I still use it.
i’d look into what QtWebEngineProcess is… chromium shouldnt use Qt. The other stuff seem fine. Modern browsers thread tabs.
Also. Just to make sure. you are not running it from snap, right?
The other test to do is to just do a clean boot and see what the RAM usage is. 11.6GB allocated when your active programs take up like 25% is very suspicious ..
My debian 13 + Gnome desktop with about 40 tabs open in Edge use 8.8 gigs. Trying to add up everything I see in gnome task manager ..
I have like, 100x more processes below 80MB. I am not going to count, but it seem like the
8.8GB does add up.
I have discord and edge open, plus a gnome-terminal. Should be fairly apparent.
