[FIX] Reboot Hang Issue on AMD AI Series Framework 13
Framework 13 Model: AMD AI 5 340, 32 GB DDR5, 2 TB gen4 SSD, Fedora 44 KDE Plasma Edition (also tested and worked on Ubuntu 26.04 Resolute Raccoon)
Symptoms: Rebooting causes the machine to de-activate the screen, however the power button remains on, and the fans remain active.
Resolution: Change your reboot method to Reboot=PCI - this allows for the machine to regain reboot functionality.
AI Generated Full Resolution Here:
Machine: framework 13 AMD Ryzen AI 300 (Ryzen AI 5 340, mainboard A5, BIOS 4.02, EC lilac - 4.0.2), Fedora 44 KDE
Linux ends every reboot by writing 0x06 to I/O port 0xCF9, an AMD *warm *reset. This SoC generation does not reliably come back from a warm reset (this is confirmed by AMD’s own open firmware, coreboot forces cold resets on Cezanne and newer “including the OS”). The EC only watches the SLP_S3/SLP_S5 which a warm reset never toggles. So it keeps the system “on”. A cold power on boot always worked.
Boot the kernel with reboot = pci - the kernel then writes 0x0E to 0xCF (instead of 0x06). The chipset then turns that into a short S5 power cycle before coming back up.
In practice this change only added about a second to the reboot time.
