Hi all! If you edit H.265 footage in DaVinci Resolve on Linux with an Intel iGPU, this might help.
Resolve Studio for Linux doesn’t use Intel’s hardware video decoder, so H.265 decodes on the CPU, and 4K footage stutters unless you make proxies. I put together a small add-on that makes Resolve decode H.265 on the GPU instead.
My setup: Framework Laptop 13 Pro (Core Ultra X7 358H, Arc B390), BIOS 03.02, Ubuntu 26.04.1 LTS, kernel 7.0.0-38, DaVinci Resolve Studio 21.1.1
Results: my 4K60 10-bit 4:2:2 Sony clips went from about 23 fps to a smooth 59 fps, with no proxies. CPU use dropped from about 8 cores to 2. Renders come out bit-identical to stock Resolve.
Installing it is one script. It checks your system, verifies the decoding matches Resolve’s own decoder pixel for pixel, and sets up your normal Resolve shortcut. If an update ever breaks something, it falls back to stock Resolve, and ./install.sh --uninstall removes it.
GitHub (code, install guide and download): GitHub - rebase-raccoon/resolve-arc-hevc: Intel Arc / iGPU H.265 (HEVC) hardware decoding for DaVinci Resolve Studio on Linux via VAAPI, no proxies · GitHub
A few things to know:
It needs Resolve Studio 21.1.1. The free version can’t decode H.265 on Linux at all.
It only covers H.265/HEVC. 8- and 10-bit 4:2:0 and 4:2:2 work.
So far I’ve only tested it on my machine. Other Intel Framework models and other distros should work but are untested.
If you give it a try, please let me know how it goes, especially on other Intel generations. Happy editing! ![]()
