Frame.work website login UX frustration
framework-login
I can’t be the only one who goes mouse-throwingly frustrated about this :persevere:
Try clicking on the icon instead of just hovering…
So the hover is just Lucy with the football, ever teasing? :smiley:
Just tested it myself and it IS quite frustrating.
If you move your mouse diagonally towards the login, the whole window disappears - as visible on your demo.
When you move your mouse straight down, it works.
The problem is - now I cannot un-see it :slight_smile:
I didn’t see the straight down part. That’s some wierd UI coding…
