Framework 12 Kensington slots
Just got a standard Kensington lock over the holidays and was surprised when it didn’t fit in either side of my FW12. Should I order a smaller size lock or has anyone else also had this issue?
I believe the Framework 12 is compatible with Kensington Nano/NanoSaver slots. Which one did you get?
I must have gotten a standard one (put it on a wish list so I wasn’t checking specs as closely as normal), and I couldn’t find the documentation on the correct size. I’ll order a nano lock, thanks!
It is nano compatible.
Maybe put that onto the product page? I don’t think it’s stated there.
Yes, I already let the team know that it’s missing.
Added to the specs page: https://frame.work/tw/en/laptop12?tab=specs
