PLEASE READ BEFORE POSTING:
Are you looking into the forum because you’re having potential issues with your Framework product? Before creating a post, we may have a guide, FAQ, or thread that can hopefully help!
In the body of your post, please include those following details.
- Which OS (Operating System)?
Ubuntu - Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
Ubuntu 24.04.4 LTS - Which Framework product (Laptop 13, Laptop 16, Laptop 12 or Desktop) and which generation of CPU (Intel 11th gen, Intel 12th gen , Intel 13th gen, Intel Ultra Series 1, Chromebook, AMD 7040 Series, AMD AI 300 Series, AMD AI Max 300 Series) or GPU (NVIDIA® GeForce RTX™ 5070, AMD Radeon™ RX 7700S)
Framework 13 with 11th Gen Intel i7 CPU , cooler master case, macbook pro 16 charger - If there is no information pertaining to your issue or question, please let us know here: Framework | Support https://frame.work/support
Hi. I have several questions about reusing framework 13 mainboard as a mini computer without a battery. Due to the intel 11th gen CPU flaws, I have constantly reset my mother board if I don’t use it for a while. I have decided to make it mini PC I can use the PC when I want to without the hassle. Yet, I soon faced some power problems and I have consult the AI but without solid answer. I intend to not use battery for laptop anymore if possible.
I have faced throttle before using the framework 60W charger only so I changed to use a macbook pro16 charger and it raised the BIO setting PL2 (Short Term) to 64W. However, the computer still freeze from time to time. I am wondering what is best settings we can have if I intend to use my framework mainboard with cooler master case? Is the extra power from the battery absolutely necessary for optimal performance? Thanks.
