Hi all,
My Framework Laptop 13 AMD 7040 lost a lot of battery overnight, even when shut down. It started a few months ago. I tried everything, search this forum and use AI and I couldn’t find any causes until I found out that the lid closing sensor it’s actually on the audio board.
Cause: The ribbon cable on the audio board was not seated right. This small board has the headphone jack and the lid closing sensor. The cable goes into a connector with a flip latch, and that latch was not pushed down. My guess is the previous owner did not close it when he fitted the new mainboard.
With the audio board removed, the battery lost about 3% in 24 hours, shut down.
When I moved the fitted ribbon cable with my finger, red LEDs lit up inside the laptop. They also lit each time I unplugged and plugged in the cable. Maybe there is a bad contact even with the latch down.
I’ll refit the board correctly and see if the drain continues. If that’s the case I’ll replace the audio board.
I usually don’t write these, but I thought it could help somebody in the future.
