Framework 13 in intrusion lights blinking
I have a framework 13 AMD 300.
I recently opened up to remove the dust and built up over roughly a year of usage when I close it back up the power lights were blinking I didn’t think much of it and then later that night on second boot they were still blinking.
I thought it might have been the covers not seated correctly so I opened it up again and closed it making sure everything is fine.
So far the only weird thing is that my right bottom screw has a clip on it while every other one doesn’t but I can’t really tell if that’s normal or just to make it pop up when you open it.
Anyway I have tried the press the SW3 switch 10 times and that has not stopped it.
Don’t really know what to do next to stop the lights from blinking. It doesn’t really impact anything. It is just annoying that I can’t easily see my power level when charging or just that the fact that there’s red lights blinking all the time.
If anyone has any ideas on how I can fix this please let me know.
Also I have been searching for the forums to find similar issues but most people seem to end the posts without saying what actually fixed it. Though I haven’t searched that hard.
Could you add a short video of the lights? Where are the lights located?
Some of the screws are captive and if they do not go down just right it will raise the cover ever so slightly.
Try opening up the framework and leave the top cover cables attached. Hold down the switch with a finger and power the device on. If the lights stop flashing then the cover just needs to be reseated in just the right fashion. If it still happens maybe take some electrical tape right where the switch makes contact to build it up a little on the top cover so it holds the switch down enough to make the right contact.
If the lights still flash even after opening it and using a finger to hold the switch, the switch itself may have gone out.
