Framework 13 laptop not charging
Hello ! it seems my laptop can’t charge anymore ! It has been used for less than a year. Following advices given previously in the forum, I have installed framework-tool and inxi.
Here are the results when the cable is plugged:
Battery:ID-1: BAT1 charge: 54 Wh (87.1%) condition: 62/60.6 Wh (102.3%)
Charger Status
  AC is:            connected
  Charger Voltage:  17104mV
  Charger Current:  0mA
                    0.00C
  Chg Input Current:2848mA
  Battery SoC:      88%
Battery Status
  AC is:            connected
  Battery is:       connected
  Battery LFCC:     4007 mAh (Last Full Charge Capacity)
  Battery Capacity: 3491 mAh
                    59.703 Wh
  Charge level:     87%
  Manufacturer:     NVT
  Model Number:     FRANGWA
  Serial Number:    045A
  Battery Type:     LION
  Present Voltage:  17.102 V
  Present Rate:     0 mA
  Design Capacity:  3915 mAh
                    60.604 Wh
  Design Voltage:   15.480 V
  Cycle Count:      7
When the cable is not plugged the output of inxi -B does not change, but the output of framework-tool is slightly different:
Charger Status
  AC is:            not connected
  Charger Voltage:  16984mV
                    0.00C
  Chg Input Current:384mA
  Battery SoC:      88%
Battery Status
  Battery Capacity: 3490 mAh
                    59.284 Wh
  Charge level:     87%
  Manufacturer:     NVT
  Serial Number:    045A
  Battery Type:     LION
  Present Voltage:  16.987 V
  Present Rate:     246 mA
                    60.604 Wh
  Cycle Count:      7
  Battery discharging
What is the charge max level set to in the bios?
The charge level has to get below 5% less than the bios setting before it tries to charge again.
So, in your example, if the bios was set to 90%. The charge would need to drop to 85% before it charged up to 90% again.
A few quick things to try:
  1. Rotate the USB-C port you’re using to each of the other three slots, see if that makes a difference
  2. Same as above, but remove all the other expansion cards
  3. Try a different charger and/or USB lead
  4. I think there is a BIOS battery reset procedure, have a search in this forum
It seems like removing the expansion cards did the trick. Thanks everyone for the quick responses !
Super. Now add them back, one by one, to see if you can see which one is causing the issue. You could run dmesg --follow in a terminal beforehand, to see if you get any errors on insert.
You may find that removing them and replacing them has now fixed the issue, whatever it was.
