Disclaimer
I am not particularly great at diagnosing issues with Linux so I used AI to assist in fetching potentially useful information for anyone reading this post.
Summary
When the laptop sits on my Thunderbolt dock overnight and suspends, it doesn’t come back properly. I unplug it in the morning and open the lid, and it’s unresponsive. The only way out is holding the power button. This has happened on two nights in a row (Oct 21→22 and Oct 22→23, 2026).
Shorter suspends on the dock (1 to 2.5 hours), including one where I undocked while it was asleep, resumed fine.
Hardware / software
Not sure if all this info is necessary, but just in case!
| Item | Value |
| Model | Framework Laptop 13 Pro (Intel Core Ultra Series 3), board FRANMJCP07, rev A7 |
| CPU / GPU | Intel Core Ultra X7 358H / Arc B390 (xe driver) |
| BIOS | 03.02 (2026-05-26) |
| ME | 21.0.6.1503 |
| CPU microcode | 0x0000011a |
| SSD | WD BLACK SN7100 2TB (fw 7615M0WD) |
| OS | Fedora 44 Workstation (GNOME 50.6 / gnome-shell 50.6) |
| Kernel | 7.2.11-200.fc44.x86_64 (6.19.10-300.fc44 also installed) |
| Kernel cmdline | rhgb quiet (no custom parameters) |
| systemd / bolt / fwupd | 259.10 / 0.9.11 / 2.1.8 |
| linux-firmware | 20261019 |
| Mesa | 26.2.5 |
| Sleep mode | s2idle only (/sys/power/mem_sleep = [s2idle], no S3 option) |
| Swap / hibernate | zram only, hibernate disabled |
Dock
| Item | Value |
| Dock | OWC Thunderbolt Dock 96W (USB4, vendor 0x5a device 0xde49) |
| Downstream TB device | OWC Thunderbolt 3 10G Ethernet Adapter (device 0xde35) |
| Port used | Left side, top port |
| Thunderbolt security | user, IOMMU DMA protection = 1, bolt policy iommu |
Power settings
- GNOME:
sleep-inactive-ac-type 'suspend',sleep-inactive-ac-timeout 900(15 min); same on battery - logind: defaults (
HandleLidSwitch=suspend,HandleLidSwitchDocked=ignore), no overrides in/etc/systemd/logind.conf*orsleep.conf*
What happens
- Laptop is docked in the evening (external display, 10G Ethernet via the dock).
- Because it’s docked, closing the lid doesn’t suspend (
HandleLidSwitchDocked=ignore). GNOME suspends it after 15 minutes idle instead. The logs show “The system will suspend now!”, not “Lid closed”. - Next morning: I unplug the dock and open the lid. The laptop never comes back, and I have to hold the power button.
Log evidence
Both failing nights end the same way. The journal stops at PM: suspend entry (s2idle) / Filesystems sync, and nothing at all is logged afterward: no PM: suspend exit, no lid-open, no Thunderbolt disconnect. The next entry is the cold boot the next morning.
Night 1 (boot ending 2026-10-21 23:18 CDT → next boot 2026-10-22 09:11):
23:18:09 systemd-logind: The system will suspend now!
23:18:10 systemd-sleep: Performing sleep operation 'suspend'...
23:18:10 kernel: PM: suspend entry (s2idle)
23:18:10 kernel: Filesystems sync: 0.011 seconds
<end of log>
Night 2 (boot ending 2026-10-22 18:14 CDT → next boot 2026-10-23 09:13):
18:14:24 systemd-logind: The system will suspend now!
18:14:24 systemd-sleep: Performing sleep operation 'suspend'...
18:14:24 kernel: PM: suspend entry (s2idle)
18:14:24 kernel: Filesystems sync: 0.008 seconds
<end of log>
Since the journal can’t flush during the hang, I can’t tell from the logs alone whether the system hung on the way into suspend or while resuming after the undock.
Suspends that worked (same kernel, same dock)
| Suspended | Resumed | Duration | Notes |
| 10-21 17:48 | 18:48 | ~1 h | Docked going in; TB dock + retimer reported disconnected ~5 s after resume (undocked while asleep), and it resumed OK |
| 10-21 19:33 | 21:11 | ~1.6 h | Lid close; dock re-enumerated after resume |
| 10-22 11:25 | 13:47 | ~2.3 h | |
| 10-22 16:46 | 17:59 | ~1.2 h | Dock re-enumerated after resume |
So undocking while suspended can work. The two failures are the only suspends that lasted overnight (~10 h and ~15 h).
Other recurring kernel messages (may or may not be related)
Every time the dock connects:
ucsi_acpi USBC000:00: unknown error 256
ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
pci 0000:56:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:57:0[0-4].0: bridge configuration invalid ([bus 00-00]), reconfiguring
pci 0000:73:00.0 / 0000:74:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
hid-generic 0003:05AC:0503.xxxx: invalid report_size 32768
Also seen at boot:
cros_ec_lpcs FRMWC004:00: packet too long (4 bytes, expected 0)
xe 0000:00:02.0: [drm] Reducing the compressed framebuffer size ... Try to increase stolen memory size if available in BIOS.
gnome-shell: Cursor update failed: drmModeAtomicCommit: Invalid argument (right before the failed suspend on night 1)
Wakeup sources enabled (/proc/acpi/wakeup)
XHCI, RP09 (NVMe root port), TXHC, TDM0, TDM1, TRP0–TRP3 (Type-C/Thunderbolt root ports).
Raw info
Collected 2026-10-23 with journalctl -b <n>, boltctl list, fwupdmgr get-devices, lspci -nn, /proc/acpi/wakeup, gsettings list-recursively org.gnome.settings-daemon.plugins.power. Happy to post full logs if helpful.
