Hi! I’ve been having an issue where my framework 13 pro (DIY)'s screen is getting scratched. From what I can tell, the scratches are coming from right around the “seam” between the top of the trackpad and the rest of the input cover. The bevel here seems to be relatively sharp, so it would make sense. I usually carry my laptop in a laptop sleeve along with my tablet (Thinkpad X12 detachable gen 1). My backpack can get crowded, but I never feel that it is so tightly packed that my screen should flex and scratch against the input cover. Other than that, It is either laying on my desk or is being actively used. Are there any habits that I can implement to keep this from happening? I don’t want to get a screen protector, as not only is the laptop not designed for that extra piece of plastic on the screen, but it would also compromise the antiglare coating.
This is probably from the space bar. It’s a common problem on all laptops, I used to get it with my MacBook Pro, and I now get it with my FW 13 Pro as well. For the Framework, I don’t find the scratches permanent - a soft cloth wipes it away.
I should think a piece of felt cut to the inner dimensions of the input area will resolve this. It should be thin enough that the unit will still comfortably close.
As far as I can tell, these marks are permanent. I tried first to wipe them away with a dry microfiber cloth, then a damp one. Both helped somewhat in that the mark was less visible, but the mark was still ultimately there. I imagine that I was just wiping away any residual material scraped up from the scratch. I may try and buy a thin cloth to place inbetween if nothing else works.
A thin piece of smooth cloth placed on the keyboard area before closing will help mitigate this. Satin or silk come to mind. It can double as a cloth to wipe away fingerprints too.
It sucks, but the main thing for me is whether the scratches are visible when the screen is on. I find that some scratches on laptop screens (and mobile phones) just disappear when the backlight is on, and scratches have to be especially severe to be visible when the screen is working.
If this is your experience on your FW, then yes, not making matters worse is key.
For the most part, the scratches are not visible when the screen is on. However, on a pure white background the scratches are decently visible. I also just confirmed that the scratches are from the bevel around the top of the trackpad, specifically near the corners. I also confirmed that my input cover was properly screwed in.
It might be worth making a warranty claim then - perhaps your set-up has an unusual protrusion that causes this problem. If you can get that then also use a piece of cloth, from the very start, might be a good idea.
Yeah, regardless of what I do I definitely need to at least contact support. Until then, yeah, I’ll probably borrow one of my family members’ glasses cleaning cloths.
