cachyos
Which release version?
Which kernel are you using?
7.2.5
0.0.3.2, 1503, 207
Framework 13 pro, X7 358H.
Plugging and unplugging the device from AC power using any of the usb-c ports (2 installed, one on each side) does not result in a plug/unplug event via powerdevil (kde-plasma).
- sysfs battery status does update to correctly reflect battery charging status, and the battery does charge.
- The power profile does not change as it should
- no sound is played as configured
repeating the plug/unplug multiple times will usually result in an event within 3 to 5 tries.
