Issue
Touchpad on the new Framework 13 (purchased less than a month ago) has almost half an inch of dead zone unresponsive space on top, left and right sides (except bottom side). Has anyone else experienced this? If so, how would I fix this? I followed all the assembly instructions and there were zero issues faced during assembly.
Arch Linux
Which kernel are you using?
6.18.9-arch1-2
$ sudo dmidecode -s bios-version
03.05
AMD Ryzen™ AI 300 Series
