Very pleased owner of a new framework 13 pro with intel x7.
Last laptop had a tb3 port, and I had e tb4 eGPU (sort of no name) with a radeon 7800xt. It worked.
However, connecting it to framework has issues.
In games it crashes hard with bsod (something related to pcie integrity) - but not right away. Maybe in the first 5 mins. Sometimes first couple of seconds, sometimes up-to 5 mins.
I also tried regular desktop work, and it did crash, but after a much longer period of time. Same type of crash.
Cable is a tb4 certified cable.
I read that on linux there’s a setting that can be tweaked to try and fix these types of issues. Any ideas on what that might be in windows? What should I try?
Not all egpu adapters are the same. There have been a few threads with the Intel Ultra 3 boards being much more selective about compatibility.
There are likely firmware issues on both sides of the issue that probably need to be released for most of them to go away. If it is an offshoot brand, chances are not good a newer firmware is coming right away.
I would even be okay to limit the whole thing to tb3 spec, or disable that bar address thing. AI did not help me that much, so I was wondering if anybody had these issues and was able to go around them.
Some of these egpu manufacturers have a jumper or a switch to for the device into a specific mode. Alternatively, maybe a TB3 cable will artificially limit the bandwidth to slower speeds. Though if the cable is too good, that might backfire!
Not having one myself, reading the threads, and from years of working with computers, lends me to hypothesize a buffer is getting overloaded or too many errors are accumulating and instead of throttleing down it goes until something gives and a full panic occurs.
A hard reset and then everything works again for a while until it happens again. It is honestly surprising there are not more companies working on developing these devices.
It is understandable that not a large percentage of laptop users would invest in an eGPU so the market is not that lucrative. The times I truly want to game or use heavy graphics on a laptop is almost always at home/work/hotel/vacation etc.
So an eGPU to plug in to get that boost is just the ticket. Having a slightly less powerful laptop that is portable and with great battery life but the ability to plug in a good eGPU is a great compromise. Especially in today’s market with how ridiculously expensive everything is on computers today.
Someone reported that they changed to a Minisforum DEG2 that has the Intel JHL9480 TB5 controller chip in it said it worked well with their 13 Pro with the Intel Ultra 3 processor. I think Aoostar AG03 uses the same chip but their previous models (like the AG02) use the ASMedia chip found in a number of eGPU controllers.
Thank you pkunk! Those are the specific reasons I bought this computer. Powerful yet ultra portable, and at home it is even more powerful with tb4 + eGPU.
I will continue to investigate this issue. Hopefully there’s a software version somewhere as well that will allow me to use the current eGPU enclosure.
Yes, I tried different cables. …all passive though.
What do you mean plugging directly into the laptop?
Really no name eGPU. Graphics card is a amd 7800xt.
No, did not test on linux.
Honestly, I gave up on it. Looking forward to a proper tb4 (or 5) enclosure.
Picture below is after I striped it down to see maybe it has some configuration. …the yellow jumper I think controls how the board gets power. Via ATX connector or the barrel plug. When I disconnect it, it won’t start.
I tried connecting the usb-c cable to the “mother” usb-c deep inside, but I think not all cables are able to connect there. Mine was too short somehow and did not manage to make contact.
Nevertheless, I stopped trying and waiting for a good offer on a Minisforum DEG2.
