Framework 16 AMD Ryzen™ AI 300 Series 10gb Ethernet port not working
so i just got a framework 16 and my ethernet 10 gb expansion is not working like at all it work for like 2 minits and stops i have the MD Ryzen™ AI 300 Series is thare a way to fix this problum
Try other ports and see if the same thing happens.
Working for a short period of time then stopping sounds like it might be a thermal issue. Could be a defect of the board or circuit inside the expansion card.
To help rule out an OS issue, try booting from an Ubuntu or Fedora live USB and see if the same thing happens. (Did not remember if it was said what OS was being used in the original post)
If another computer is handy that has a USBC port maybe try using the adapter on it. If it follows the adapter then that is what is defective. If it goes away then it is a mainboard or OS issue.
Start a ticket with support, we are all end users here on the forums. Those are still fairly new, and it could just be one that did not pass QC but shipped.
Enjoy the new Framework Laptop 16!
Oh BTW, welcome to the community @Riley_knowlton !
Me too, I might try working to fix it tonight, if I get anywhere ill let you know. I am on windows 11 and it never worked even before OS install
i fond a fix but it was a pain in the bit if you run windos 11 or other os,s run the bios up date and the other app to fix the wfi port i dont reember ware to git it to be franck and make sor windows is up to date to a working one
BIOS and driver update packages can be found here:
I am having the same problem reported in the first post. Framework 16 with 10G Ethernet Adapter. I ahve tried several ethernet cable between the NIC and the ethernet camera, and the NIC does not connect. Other laptops (non Framework) connect fine. The laptop just arrived this morning so I have to assume it has the latest firmware/bios/drivers.
I moved the adapter to a different port and it connected, but only for a short time. Then the adapter disapears. I rebooted, and the addapter did not reappear until I unplugged it and plugged it back in.
When plugged back in it disappears after a few minutes.
Your BIOS is likely up-to-date, but it’s pretty likely that you’ll want to install the latest driver bundle. I’m guessing you are running Windows, but if that’s not the case this won’t apply. I’m also assuming you’re running one of the AI 300 Series mainboards, but if not, you’ll want slightly different links that correspond with that product line. If using Windows and an AI 300 Series mainboard, go to this page and download ‘Windows Driver Bundle v2.0.0,’ then run the .exe to install the latest drivers:
After that, you’ll want to make sur you’re using the expansion card in one of the proper ports of your machine. Here’s Framework’s page discussing which ports the WisdPi Ethernet expansion card will work in (and the expected potential network speed for specific ports):
After reading THAT page, you’ll find links to the USB Port Definition Matrix page for Framework Laptop 16s near the bottom of the ‘Functionality’ page. You’ll note that all ports support USB 3.2 Gen 2x1 protocols, although I think I’ve seen issues using Ethernet expansion cards in slots 1 and 4 (I could be wrong, though). You might be best served to use it in ports 2, 3, 5, and 6 if that IS true. Link to the ‘Definition Matrix’ page:
Finally, you might not know which ports correspond to ‘ports 1-6.’ There’s a link in that ‘Definition Matrix’ page that will show you what’s what. Link:
my ethernet just started working, maybe try bios and drivers?
On a newly delivered Framework 16, the BIOS and Drivers are up to date, so this is not the problem with the Realtek 10Gb USB Ethernet.
The actual problem stems from Microsoft’s Windows 11, which assigns this newer high-bandwidth controller to Microsoft’s NetAdapterCx (Network Adapter Class Extension) driver framework rather than legacy NDIS. Most users are not seeing this specific problem because they are not using their laptops to interface to GigE Vision/Genicam Cameras over ethernet. Users who do try and connect using Microfost’s NACx will get no devices listing.
The solution is to dowload the Windows 10 Realtek drivers, Install 7zip so the driver installer can be extracted, and then replace the driver from the device manager, pointing to the INF file in the extracted files.
Realtek Drivers
7-zip
Terrific find! I’ve confirmed that this is working for me. I’ve been chasing this problem in windows since i got my laptop earlier this week. Finally have 10Gb speeds now.
I think this is worth notifying the Framework devs as these adapters do not work right out of the box for Windows currently.
