I currently have a Framework 13. I’m considering upgrading to a Framework 16 with a beefy graphics card, potentially sucking in 240W.
One issue is that not a single docking station provides that much power at the moment. ‘No problem’, I thought to myself. ‘When I want to game, I’ll attach my Framework 240W charger to the main port and attach the dock to another port. No big deal.’
My question is: is this possible? Will the two chargers not interfere? Will my Framework 16 select the most powerful charger and NOT the docking station one? And finally (but this might come down to my specific Archlinux setup) will the docking station work with external screens on other USB C ports than the main one?
Yeah, it’ll work as you expect. The FW16 will identify the highest power charger and use that. I’ve tested this with secondary chargers up to ~100W, and the intended charger has always been selected.
Note: It will not pull power from more than 1 charger at a time.
The Bluebuilt DisplayLink seem to be a USB video adapter, not a USB Display Port Alt mode adapter
It specifically says that you 1. need software and 2. cannot game on the extra screen.
DP Alt mode is native DP, it wouldnt care. This is DisplayLink, which is .. not that.
If you need a hub that can do power pass through, just look for one that has display and/or power. they usually do 90W. like dell da 310/305(300 is without power passthrtough).
this
or the like.
I imagine they cap at 90/100W because they dont do EPR
(so, 20V 5A cap), and they acount for some internal hub power draw.
I dont think thunderbolt help, ironically. thunderbolt is in theory point to point. you can daisy, or like, hub. but. i imagine few actually use it as such.
You can daisy chain DP though. thats almost always supported
