Framework 16, Fedora + bazzite dual boot problems
Hello all!! Have been using my framework 16, ryzen 7840HS + dGPU module for a couple years and it’s been nice. However, i am trying to make the switch off of windows 11 and replace it with Bazzite since gaming is all that I really use Win 11 for. I have two SSDs installed, with the OS’s on separate drives. Fedora + win 11 has given me relatively few issues, but when replacing windows with Bazzite I think grub freaks out since both OS’s are labeled ‘fedora’ in some kind of efi boot manager from what i remember. I am not able to boot into either OS using the BIOS (a solution I have seen posted with other laptops), is there a way to change Bazzite’s name in the boot manager somewhere so I can just choose between the two in grub? Am still kind of new to the internals of how linux works. Thanks everyone who helps <3
Hey! Have you created a support ticket? If not, please do so and ask to speak to the Linux team and let them know the issue you’re having. Our Linux team will be happy to help you out!
One of the Linux uses can answer this better. Lots of them on the forums.
I believe there is a configuration file that grub uses that can be opened with a text editor and change the description of each entry.
