Framework 16 GPU Upgrade?
Got it, so the one actionable thing I’m seeing here is: Check Cinebench R23 to check if I’m affected by a thermal issue, inline with the “uneven CPU thermals” thread
Use the mesa drivers
@knipp30 , are you referring to a packaged DKMS module? I don’t know what you’re talking about because I don’t see it in the documentation at Xorg - ArchWiki , so could you please clarify? Currently, I am using the built-in amdgpu driver in the kernel and Mesa user-space drivers, which I think is also what you suggest in your post.
I am referencing this. From my understanding, even in arch, this should not be needed.
The amdgpu drivers should be packaged within the kernal already.
Installing amdgpu by yourself can (and often does) lead to issues.
It could have been confusion based on the above statement - but its not clear what you mean by stating you installed amdgpu - since that should ship with the kernel.
The arch subreddit is full of people who will just point you to the wiki:
https://www.reddit.com/r/archlinux/comments/17zgz7b/i_am_new_to_arch_and_linux_how_can_i_install_amd/
But they even state the same, and the wiki doesn’t really point to “installing amdgpu”
AMDGPU - ArchWiki
Yes, I thought I might have installed amdgpu manually, and then I realized that I had not, so this shouldn’t be an issue. To be extra clear:
$ pacman -Q | grep -i amd
amd-ucode 20250210.5bc5868b-1
amdgpu_top 0.10.1-1
amdgpu_top-debug 0.10.1-1
And I remember this was called Radeon when I was a kid, so:
$ pacman -Q | grep -i radeon
lib32-vulkan-radeon 1:24.3.4-1
Hopefully these are fine too.
