Framework 16 lid sensor replacement
Hi, everyone.
I broke my lid sensor because I wiped my screen with a cloth that was too wet and some drops dripped down onto the sensor.
Now the sensor constantly thinks my lid is closed and it turns off the screen, keyboard and the power button light when i reconnect the small sensor cable. Also the power button doesn’t work anymore unless i disconnect the sensor.
Sadly i can’t find a lid sensor replacement in the shop. Didn’t i look hard enough or isn’t there any available?
