Framework 16 Screen Compatability
Correct. But I dont know if it read EDID or not.
well that’s unfortaunte. I had thought about this, because framework didnt provide nearly enough ground pins for that. You can use shell return, but then again.
Well. From various sources above you can tell that it is not displaying anything.
It is the main criteria for a display being recognized and since it doesn’t do that it’s a pretty safe assumption.
I don’t mean separate as in electrically isolated but they just don’t care about what the other is doing.
Yeah without the edid the laptop is likely not even attempting to.
There was someone who managed to hook up a miniLED screen a while ago… Mini LED Replacement Display . But it looks like they used an EDP driver board instead of running it straight from the display out of the motherboard. I’ve searched the Lotus branch of the EC repo, (the one that relates to the FW16), for anywhere obvious that you could change the number of display lanes, but can’t find anything.
how do we know if it is recognized (but didnt pass link training) or that nothing happens (and no link training happens)
We can of course double check the wiring .. schmatics, but I dont think I made any mistakes
That it show up as a display to the system. Dummy plugs will also not pass link training but show up just fine.
Right, but keep in mind that Sixteen have a mux that does its own link training.
And as far as I can tell, this is a “black box” type device. There’s no public datasheet available.
The thirteen, however, don’t. This is why I am planning on trying my display on that.
Since we have demonstrated that plugging my display (with the cable) into the 16 board will not cause catastrophic failure on the board side
Why don’t we go over the display connector at some point.
Yeah the mux is certainly not simplifying things
So. No response from Twitter X, and no response (basically) from support either.
I can however ask support and pretend my display wont turn on entirely. But they wont task me with the task of soldering debug probes to the system embedded controller, and will just let me return the thing. Which isnt super helpful.
You don’t need to solder. You got a ccd? It’s pretty easy to diy if not.
Then again for display troubleshooting an external display or even just enabling ssh would probably do the job already.
how do I do that?
