- Operating system: Microsoft Windows.
- OS release / edition: Windows 11 Pro, version 26H2, build 26300.9711.
- Framework product: Framework Laptop 16.
- CPU generation: AMD Ryzen 7040 Series.
- GPU: AMD Radeon RX 7700S.
Additional info:
RGB keyboard and RGB macropad
BIOS 04.05; EC 4.05; PD 0.0.21
Framework 2.5 GbE Expansion Card with Realtek driver 1156.13.20.420.
I’m investigating a problem where my 2.5G Framework Ethernet Expansion Card disappears from Windows after a cold boot, followed by intermittent keyboard and macropad interruptions during that time. I originally started to notice this after the first 4.x BIOS Upgrade was released. I’ve collected USB traces and worked through a series of comparisons.
When the card fails, it disappears as a USB/network device, not just as a disconnected Ethernet link. It can stay missing until I physically remove and reinsert it the card. While that failure is active, the RGB keyboard and RGB macropad intermittently go dark and stop responding for around ten seconds at a time. A held key when this happens continues to repeat until the keyboard and macropad “reconnect”. The touchpad continues working, although movement can hitch. If an active Ethernet connection is on the adapter, this connection dies and doesn’t come back. I dealt with this problem for months, and then by complete circumstance I had to remove my Ethernet Adapter for a 2 week work trip and noticed that the problem with my keyboard didn’t seem to happen anymore. When I got back, and plugged in my adapter, it started happening again. But then what I noticed is that if while Windows is running, I just pull the Ethernet Adapter, and plug it back in, everything works without issue until the laptop is shut down and started the next time.
The sequence that has reproduced it most consistently in my recorded tests
- Start with the original Ethernet card present and healthy in Windows, directly in left-middle, slot 2. I had traditionally tried this slot because it seemed like the “right” place for a module like this that uses USB Gen 3.2, while saving my few USB 4 ports for docking stations and higher bandwidth stuff. I have tried other slots too.
- Leave the card fully inserted and untouched. Perform a full Windows shutdown.
- Wait approximately 30 seconds after visible power-off, then use the power button to start the laptop. Check whether the card returns in Windows.
All three recorded trials with that specific starting state and sequence failed to bring the card back:
| Recorded startup, October 23 | Power | First port-change failure after Windows kernel start |
| 10:30 CDT | Charger attached | 5.242 s |
| 15:17 CDT | Charger attached | 5.145 s |
| 21:16 CDT | Battery, no charger or dock | 7.260 s |
This is a small, sequential set. I can’t claim this happens 100% of the time. On this particular laptop, it happens over 90% of the time.
The missing card is the quick reproduction indicator. The keyboard/macropad outages are intermittent later effects; they did not happen in every short startup capture. Trying to get to the bottom of this, I learned that Framework has a framework-tool winget command set that let me at least dig into the USB status stuff. I also dug into how to perform USB traces because the Keyboard and NIC issue seem related but I couldn’t really see how. There wasn’t really anything of value showing up in Windows Event Viewer, and I never heard any dreaded “windows disconnect / reconnect” noises.
Me running some of the USB Trace information below:
Windows repeatedly tries to initialize the affected connection without reaching a usable Realtek identity. Here is a selected, reformatted native event from the battery failure. Times are relative to Windows kernel start, status values are shown in hexadecimal. I left off Machine identifiers that are also part of some of that output data.
Failed left-middle startup (battery, RJ45 empty)
+7.2595668 s USBHUB3 event 123: Failure during Port Change Request
PortNumber = 1
PreviousPortStatus = 0x0101
CurrentPortStatus = 0x0100
CurrentPortChange = 0x0011
Vendor ID / Product ID = 0 / 0
Successful RTL8156 identification in the completed trace: none
That port is the USB2 side of the same physical connector used by the card’s SuperSpeed connection. The event itself doesn’t name the card or contain a hub pointer; its association with this connector comes from the surrounding port-status records, topology and unchanged hardware. Vendor/Product zero means no usable identity in this event, not a device with a real “0/0” identity. In other words, when these are happening, the card is unable to identify itself on the bus.
For a comparison, I moved the failed card to left-rear (near the laptop hinge) while Windows was running, recovered it, then left it untouched through another battery shutdown/start. That startup passed. These are counts calculated from the same 150-second interval in each trace, after initial startup:
Same 150-second window: Windows kernel start +60 to +210 seconds
Left-middle Left-rear
failed start healthy start
Enumeration starts, all ports (event 60) 744 0
Port-change failures (event 123) 868 0
Port-change failures per minute 347.2 0
Retry Enumeration (event 62) 0 0
Port Reset Timed Out (event 65) 0 0
Hub reset requests (event 120) 0 0
Internal controller resets (event 28) 0 0
The failed recording contains 131,312 USB events and no successful card identification. The healthy recording contains 11,270 USB events, with the card identified at kernel+8.0552985 seconds. Both report zero lost events and zero USB decoding errors. The complete recordings have different lengths, so their total event counts aren’t used as a rate comparison. Zero resets in these short windows doesn’t mean the sustained failure is harmless: across two other recordings, five root-hub requests led to successful XHC0 controller resets and rebuilding of the internal input-device connections.
Other things I did to try and troubleshoot over the months
- Unplugging RJ45 alone did not stop an established failure. Removing the card stopped the repeated errors; reinserting the same card in the same slot recovered it in several trials.
- A genuine Windows Restart from an already failed card state did not recover it. Also if the card is already working, restarting the system has no affect on it. Only cold booting with the card installed seems to trigger the issue.
- First attachment after starting with the card absent failed once and succeeded in a repeat, so “the first insertion always fails” isn’t a guarantee.
- I also have an HP Thunderbolt 4 Ultra 180W G6 Dock that I use for work and with this laptop. For those not familiar with it, this dock, when run in USB4 mode instead of Thunderbolt, has a 2.5G USB NIC that is also based on the RTL8156. It has never given me issues. The same Framework card, connected through an HP dock’s 10G USB-only side port, worked through startup and a separate dock power-on. The dock’s built-in RTL8156 is a different device hardware revision. My point here is that the Network Card only seems to fail when directly plugged into the Framework, not any of my other systems, and not on the Framework if the Dock is sitting in between.
- I have been getting better results lately when using the USB 4 ports on left and right with the Network adapter. But this is very wasteful and takes away one of the ports for me to use with my dock.
Framework’s 7040 slot guide lists USB 3.2, DP and charging support for left-middle. I also found Framework engineering’s comment about reverse-current protection on ports 4/5, but I don’t know whether that applies to this 7040 Slot 2 case. My separate Anker charging trouble above 100 W hasn’t been tied to this: the Expansion Card fault occurs on battery power, and the HP dock at 180 W EPR during successful observations.
Has anyone seen this combination? Card healthy before shutdown, left installed in one of the USB 3.2 slots, absent after startup, then input interruptions; and found that simply pulling and reinstalling the card fixes it?
I’ve thought about trying to get another Framework NIC, but honestly the fact that this NIC works in my other systems, including if I put my dock in between, and seems to only fail in this Framework seems to indicate to me that this is yet more USB negotiation issues that may be Firmware related, rather than the NIC’s fault.
I have not opened a Framework Support Case on this yet. Admittedly, it’s on the to-do list, but this system is out of warranty, and honestly the last support case where I was trying to show support the bugs in how the laptop handles 28V power was ultimately such a tremendous waste of my time it turned me off of starting that avenue until I knew I had spare time to just throw into the void. I figured I’d first see if others have been dealing with forms of this too and if they’ve maybe found a better solution than just “unplug it / plug it back in”
