Framework 240W, 180W & 100W Charger -- PFC?
The Framework 60W GAN charger is very nice bit of kit. Very compact, and quite efficient.
However, it has absolutely atrocious power factor, of 0.5 to 0.6. Yeah it pull 60W, but it pull 90VA (“apparent watts”) from the wall. This leads to quite a bit of heat.
What about the 100W and 240W? I think regulation force you to have PFC, but. Are we doing the same old “delete PFC to make charger smaller” trick?
No! GAN doesn’t automatically make chargers superior. GAN is just better MOSFET, so you can run them much faster.
Higher frequency means a smaller core, so you can shrink the magnetic core still. which shrink the charger and make it lighter.
In case you are looking for alternatives, Lenovo make some pretty decent 65W and 100W units. They are not as small, and they are not necessarily GaN. But they have PFC, too. And. surprise, they dont get nearly as hot.
Are they also grounded?
Regulation limits harmonics. At roughly 70W input, PFC is required to keep harmonics low.
Power factor is not efficiency. Efficiency is output active power divided by input active power. Heat generation is input active power minus output active power. However, high quality power supplies often have both good efficiency and good PF, which may confuse the user.
