Framework Desktop BIOS settings keep resetting to defaults
Each time I unplug the power supply the bios factory resets to defaults. I’ve owned the Framework Desktop for less than two weeks. I spent a couple hours yesterday troubleshooting a delayed boot issue only to discover its a bios bug.. but each time I swapped a SSD (with power unplugged) I had to reconfigure bios settings.
I checked to make sure the CMOS battery was installed, it was, but underneath it appears to be a some residue. Is this at all normal? The delayed boot issue plus this makes the product feel buggy expensive toy that isn’t stable.
Pics of the residue - Imgur: The magic of the Internet
Did you try with a different battery?
