Framework Desktop not booting
Hello,
Today my Framework Desktop became unable to boot even though it was fine yesterday. I have been updating Fedora almost daily as new updates are very frequent these days. It is unable to find the SSD that was provided with Fedora. What should I do? Thanks!
My setup:
Framework Desktop (AMD RYZEN AI MAX+ 395 w/Radeon 80605
Fedora 44
BIOS: LFSP0.03.06
I’d start off with booting into the BIOS and finding the boot drives screen - see if it can see the NVMe drive. If not, power it down, open up the case, and see if the drive needs re-seating.
Next, get Live Ubuntu on a memory stick and see if you can boot into that. Of course, if you don’t already have that, you will need another computer to get that image written. If you can boot into an operating system, that will give you access to disk tools to inspect whether the computer can detect the presence of the non-booting drive.
In general this error comes about because the NVMe drive has failed at a hardware level, it has become disconnected, or the boot sector has corrupted.
Do you have valuable data on the drive, or is it all backed up? Rescuing data from the drive is often possible, but it may make the fix operation a bit more involved.
