Highlights
- Updated the AMD PI code to version 1.0.0.2.
- Added support for 3A charging profiles on USB-C ports, enabled only when the BIOS setting “Force power supply on in standby” is set to “Enabled.”
- Improved the PXE Boot behavior, ensuring the system automatically attempts the next boot device upon a network boot failure.
- Enhanced the Power On AC behavior, allowing the feature to work correctly without requiring the system to boot into the Operating System at least once for initialization.
- Fixed an issue where the system incorrectly showed an “invalid supervisor password” error when the user set the TPM to Hidden and set the supervisor password in the same BIOS session.
- Fixed an issue where the storage password could not be removed after being set in the BIOS.
- Resolved a bug preventing the specific keyboard from functioning while in the BIOS interface.
You can check your current BIOS version following the steps here to determine if you are on the latest release.
After the beta release, we will monitor community feedback, and publish this release to our stable release channel after approximately one week if no major issues are reported.
Subscribing to release notifications
If you want to subscribe to new release notifications you can now opt in through this link to receive an email when we release a new BIOS or driver update for your Framework Desktop.
Downloads
Windows
| Download Link | SHA256 |
| Framework_Desktop_Ryzen_AI_MAX_300_BIOS_3.04.exe | BC365DC789549C16700DB05B02CE9CAD83ECE2D8A023759C1E8C3596737E3E2D |
Please do not interrupt power to your desktop while the update is in progress.
Instructions for Windows Installer:
- Run the .exe.
- Click yes to reboot.
- Wait for the firmware progress bar to complete, and then the system will reboot.
Linux/LVFS
Updating via LVFS is available in the testing channel during the beta period.
You can enable updates from testing by running
fwupdmgr enable-remote lvfs-testing
Please note that you must update with a charger attached, then run::
fwupdmgr refresh --force
then
fwupdmgr get-updates
then
fwupdmgr update
Linux/Other/UEFI Shell update
| Framework_Desktop_Ryzen_AI_MAX_300_BIOS_3.04_EFI.zip | B589ED7D853250FD9B5CCD9A41AC2F37D4050FE31025BE7402FA1BEC69C72254 |
Note that if you use the EFI shell update with Windows, you should suspend Bitlocker if enabled before updating using the EFI updater.
Instructions for EFI shell update:
- Extract contents of zip folder to a FAT32 formatted USB drive. Cleanly unmount the drive before physically removing it, otherwise the BIOS update may not function correctly.
- Set the ESP flag for the FAT32 partition.
- Boot your system while pressing F12 and boot from the thumb drive.
- Let startup.nsh run automatically.
- Follow the instructions to install the update.
Security Fixes
N/A
Enhancements
Fixes
Component Versions
This BIOS update is a bundle of updates to multiple embedded components in the system.
Not all of them use the same version number.
| Firmware | Version | Updated? |
| BIOS | 3.04 | Updated |
| EC | ec_304_a4ef660 | Updated |
| PD | 0.0.0E | Same |
| AMD PI | StrixHaloPI-FP11 1.0.0.2 | Updated |
Reporting Issues
To report issues we have created a public issue tracker on github. GitHub · Where software is built We hope that this is a better way to track issues with community involvement moving forward as we have found it difficult to both gather relevant information about issues people are reporting on the forums, and track the issues through their lifecycle in a transparent way.
If you do experience an issue with the update that is related to your system firmware, please post as complete a description as you can, including relevant system information, and external peripherals. Please note that we do not currently have a SLA for responding to issues on github, but we will be reviewing them through the bios release process, and will review them for future updates as well.
If you have an issue regarding hardware, broken devices, returns, etc, this is not the place, please contact support.
Known Issues
N/A
