Framework Laptop 13 Ryzen 7840U mainboard failed after 2 years. Replacement out of stock
My Framework Laptop 13 (Ryzen 7 7840U) (Windows 11 26H2), purchased in June 2024, suddenly stopped booting on October 26 after previously working normally. There was no physical damage, hardware modification, or recent BIOS updates. After over a week of troubleshooting with Framework Support, including testing different RAM and SSDs, performing mainboard resets, power drains, and external display testing, Framework concluded that the mainboard needs replacing.
Framework has declined my requests for assistance with this replacement. They also acknowledged that they cannot determine what caused the failure without board-level diagnostics, which they don’t offer. Framework then extended that I should buy a replacement on the marketplace, however, the exact Ryzen 7 7840U mainboard is currently out of stock on their Marketplace. This leaves me in a position where I either have to wait an unknown amount of time for a $449 replacement to become available or spend even more money upgrading to a newer model just to get my laptop working again.
Downgrading to a cheaper, older mainboard isn’t even possible either as the Ryzen 7040 series was the first generation to use DDR5, meaning older DDR4 mainboards more commonly available through third-party resellers wouldn’t be compatible with my existing memory. I’d have to purchase replacement RAM on top of the mainboard, adding even more expenses.
It’s pretty frustrating to have such a critical component fail unexpectedly after only about 2 years and 4 months of normal use, especially when the recommended replacement isn’t even available to purchase.
Has anyone else experienced a similar failure with the Ryzen 7040-series mainboards? Were you able to find a reasonable resolution or alternative repair option?
I’d really like to get this laptop working again without having to spend hundreds of dollars replacing a component that failed without any apparent cause.
Hi, I’ve become pretty familiar with those boards. If you have some experience with electronics, I can help with fixing it.
First of all - what are the symptoms? Zero power, boots but no display, something else?
FWIW, friend of mine had 3 boards “die” on him in similar way (Intel MeteorLake, 13th Gen). I had a look at it and determined that the board itself was fine, but rubbish insyde firmware managed to brick itself during normal use.
I wouldn’t be surprised if the same thing happened here, especially if you’re running Windows (which can pull/install firmware updates without user noticing it).
Hi, thanks for offering to help! I do have some experience with electronics and am willing to try and fix it with some help.
The symptoms are: The power button lights up white when pressed, fans sometimes spin, the CPU gets hot fairly quick but the laptop never boots or displays anything even with an external monitor and the internal display disconnected. In this state it also gives a diagnostic LED code of 1W 12G 1R 1B 1G 1B 5G.
Additionally, a few days prior to the full laptop not booting I encountered 2 BitLocker bluescreens unexpectedly without ever manually updating anything but to your point Windows often has a mind of its own.
Thank you for offering to help! And let me know if you have any more questions.
Framework doesn’t force firmware. You have to manually run exe to install BIOS on Framework computers
That does sound like a firmware issue, if your system doesn’t shut down within 10 seconds it means that:
  1. EC receives an eSPI response that x86 is up
  2. PSP blobs are loading, so x86 gets released from reset
  3. Where it fails is likely x86 portion, so as I initially suspected - it’s a “BIOS” issue.
This can be fixed with cheap, 1.8V capable SPI flasher and WSON probe. Shouldn’t cost more than 20EUR and you can fix it without even removing the board.
Some people here in the forum managed to unbrick their systems which failed in similar way and explained it in a really nice way, I’d recommend trying that.
There have been reports of faulty batteries causing problems like this. Try removing the battery and then boot.
By your description, the problem is a hardware fault of some type.
no official board-level diagnosis and no official schematics. so much for right-to-repair
The AMD AI 7 350 is more expensive and has a worse iGPU, the 9 HX 370 has a better iGPU but worse battery life and more expensive. so the best replacement would be the Intel Ultra 1 Series 7 155H
You probably know better (I haven’t used Windows in a decade), simply mentioned this as a possibility given I’ve seen this happening with other system vendors in the wild.
Not really Framwork’s fault. Same goes for Valve’s products (like Deck or Gabecube), who use the same board OEM and said vendor is very strict about it.
Thank you and I have now done some research on this procedure. I think I will try it because what’s the worst I can do to an already bricked mainboard.
My main question here is really how this would have happened as to the point of:
and I have never run an exe to install any BIOS update on this laptop. Could this really be a “Windows is Windows and updates whenever it pleases” issue?
Correct, Windows does not force BIOS updates for Framework devices. All firmware updates have to be initiated by the end user.
There are some select circumstances where Windows will push a firmware update from a vendor through Windows Update, this is almost exclusively done with Microsoft branded devices (Surface machines)
Thinking about this a little more; something triggered the Bitlockery screens which means something changed. It could be a corrupt value especially stored in the EC or another subcomponent and now it fails to pass POST.
Carefully following the main board reset procedure if it has not been done already might clear the BIOS to a bootable state. Just for good measure, remove the SSD. Baring that, maybe try booting the board completely standalone outside the laptop?
