The Problem: I recently bought a 2nd Gen Storage Expansion Card and installed Windows To Go on it using Rufus. However, the drive is completely undetected by my Framework 13 Pro (Pantherlake).
Symptoms:
Does not appear as a bootable device in the BIOS (USB boot is confirmed enabled).
Does not show up in Windows Disk Management.
Does not mount or appear in Fedora Workstation.
The only error message I received was a Windows popup stating: “USB device not recognized.”
Troubleshooting Steps Taken: To isolate the issue, I verified the drive is fully functional by testing it on several other devices. It works flawlessly on:
My iPhone.
Two different Windows 11 PCs (using 10Gbps USB ports).
My ROG Ally X (successfully booted the OS).
I also tried swapping expansion ports on the Framework itself, but the drive remains undetected.
Note: I don’t have the machine with me right now, so I won’t be able to run additional tests. Has anyone else run into this specific issue with the 2nd gen cards on Pantherlake, or have any ideas on a fix?
