Front Right Chassis-Keyboard Gap
I received my framework 13 pro however when I try to put it all together I always get this gap in the front right between the keyboard and the chassis. It never seems to fit snug in that corner even though the other corner fits fine. Should I request a new keyboard module or is there a solution? My current theory is maybe it has something to do with the metal spring knob that pushes this side up to make it easier to access/remove or that the keyboard simply wasn’t cnc’d perfectly and therefore is just enough to not fit. I know the instructions state that this is expected before screwing it but this is after screwing in so I don’t understand why the gap is so noticeable. Ultimately, I’m not the most familiar with these laptops and I don’t want to strip the screws or something, it seems like if the left side fit so snug, the right side should as well.
When you tightened the screen on this corner, did you get a “bite”? The screw could have already been stripped or be otherwise tight. If you are not sure, swap the two front corner screws to see if that pinches the right corner down (on the basis this screw is probably fine).
I’d also consider re-wobbling the keyboard/touchpad into place, in case it has been clamped down on a wrong internal lip.
It maybe possible the screw is partly stripped but it think its very unlikely as it screws down all the way and doesn’t feel stripped. I did try to swap the screws and it didn’t work either. Also when I squeeze that corner with my hand I’m still unable to close the gap. I’ve taken the part out and put it back many times try to see if wires or the touchpad is holding it up but they all seem perfectly fine the issue is perfectly replicated every time I put it back together. Thanks for your help!
No worries. Others with mechanical knowledge of the chassis might want to chime in. However, it’s worth logging a support call too. Be willing to do several loops of photos and investigations! But it may be worth it, they sometimes will send a new part.
Note that there is a similar report from not too long ago on r/framework. No solution there, but if nothing is deformed and you can’t press the two flush, it may be that there is a manufacturing or assembly error that multiple users have experienced now.
Thanks for the help, unfortunately, I already looked over that post and none of the potential solutions worked for me.
Hey! Give our support a shout. We will be happy to help!
Thanks, I submitted a support request earlier but I never got a confirmation email so I’m worried it never went through. Should I resend another another or is there another way to view support requests?
Sent you a DM :slight_smile:
