Function key sticking (again?)
Fedora
Which release version?
43 Wayland
Which kernel are you using?
6.17.7-300.fc43.x86_64
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: INSYDE Corp.
Version: 03.04
Release Date: 06/10/2025
ROM Size: 32 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 3.4
AMD Ryzen™ AI 9 HX 370
My framework experience has unfortunately been quite problematic. This is my latest problem:
I use tdrop to toggle my terminal (F12). However, pressing F12 sometimes prints tildes (~) non-stop. It happens about 50% of the time and only for external keyboards (I tried three external keyboards, and the problem is present for every one of them).
The issue is very similar to this problem of function key sticking:
And I have tried the quick fix in that forum post and resetting my motherboard:
Nothing seemed to fix this issue. Anyone has any suggestions on how to diagnose or fix this issue? evtest doesn’t show anything suspicious.
