FW 13 AMD 7640 - Replacement Battery Stock / Known Issue Warranty Stock
Specs:
  • Laptop 13 AMD 7040 Series
  • 61 Wh battery
  • Windows 11 26H2
Is there any timeline on FW 13 battery replacement stock?
Super frustrated right now because FW13 had known BIOS defects to prematurely degrade the battery. I adhered to the multiple BIOS updates that were supposed to fix the underlying issue. But the damage was already done, and here I am getting warranty denied 1.5 months outside of the warranty. Normally, I’d would understand being outside the warranty period but its just so frustrating to know the BIOS was plagued with issues compromising the battery but we couldn’t submit warranty requests for known compromised units until they showed the damage.
Regardless, the Company built on repair-ability doesn’t even have batteries available for me to purchase. You’d think for a part encountering known issues they would have plenty on stock for warranty claims, let alone having the part available for purchase to those encountering the exact defect. Especially, if you’re going to deny the warranty simply because it didn’t make show visible signs of the known defect issue just a few weeks earlier.
As for the support suggestion of removing the battery and using it stationed? I bought a laptop, not a desktop because I need the physical portability where there’s not always outlets. A laptop’s not a laptop without a battery.
So when will these things be restocked?
The battery warranty is extended on top of the laptop’s warranty.
Also no, the latest BIOS doesn’t fully mitigate the problem. It’ll only discharge the battery to 85% after being continuously plugged in for more than 3 days. Unplugging without discharging the battery (like when switched off) can reset the counter so it’s better to set the battery limit manually.
The supply shortage is not limited to just Framework. Everyone has supply chain issues in today’s world.
There are some 3rd party batteries for sale elsewhere but I would not personally trust them vs. the quality Framework has set out for their batteries. This is a solution though just not the ideal one.
The 55Wh battery is in stock, at least at the German shop. If you have to restrict the 61Wh battery to 85% (52Wh) to survive longer than a couple of years, you can also use the 55Wh battery without any restriction :wink:
Where are you based? I have pontificated in this forum that a consumer could take Framework to their small-claims court, if their prevailing consumer legislation were to permit it. I have surmised that here in the UK it is likely that such a case would be fairly easy to bring, and one would not need a solicitor. I think the basis of any such case would be “fitness for purpose”.
For what it’s worth, I don’t think any such claim need to be viewed, by any party, as adversarial or hostile. It’s just a process to help enforce consumer rights, which all parties should be in favour of. UK and US consumers are especially protected because FW are incorporated in both countries (they may be incorporated elsewhere too, I don’t know).
US Shop - 55Wh and 61Wh both out of stock.
Hard to say what you really get in the German shop: if you click on the only available option “Framework Laptop 13 Battery - 61Wh” you get a product description about the 55Wh battery but also SKU FRANGWAT01 - what seems to be the 61Wh battery :man_shrugging:
US shop just restocked new 61Wh batteries a few hours ago. I’ve got an order in with a confirmation.
