Short summary: This morning, I installed a security update on Fedora, rebooted, ran into pre-existing issues around the laptop not booting when power is connected, tried to get the firmware update to work by timing when I connect power, and somehow ended up in a situation where the FW doesn’t boot - nothing on screen, single-pressing the power button doesn’t turn it off. Long-press needed to force it off.
System info: Framework 13 w/ Ryzen 7 7840u, chassis was ordered when that mainboard was the best option available, if that helps. Current version of Fedora Workstation KDE edition; updated to whatever was made available this morning of 2026/10/26. Update was installed probably by 10:00? UTC-7:00
Context:
Pre-existing turn-on issue:
My FW13 has an issue where it won’t turn on if it’s connected to power for the first few seconds. If power is connected it will turn on to a black screen, and can be turned off by single-pressing the power button. I believe this started sometime this year when I went back to having power on when AC connected disabled.
For example, when it restarts for an update, I have to unplug power so it can turn on. It will freeze even if the Framework logo shows. Once the Fedora logo shows up, I know it’s at the point where I can plug it in without interrupting the boot process.
Note: All of this is when using my ~90w Dell WD19S thunderbolt dock. This is the only adequate USB-C power supply at home, and I haven’t tested other power supplies. The dock has no noticeable issues. I don’t know if the dock could have anything to do with this.
Firmware update issue:
This inability to boot with power connected obviously conflicts with firmware updates, which require power to be connected! I have ran into this a few times: It will say smth along the lines of Please make sure AC power is connected in red. By the time I plug in power it will say Firmware update failed! in red. I can then single-press the power button to turn off and try again. Usually, I am back to using my FW shortly after this. It’d either eventually resume booting, or skip the firmware update on the second attempt. Once, it kept turning on to the firmware update screen. I don’t remember what I did to make it boot, but it did.
Current issue:
This morning, I got a notification from Discover, Fedora’s GUI package manager - security updates available. Yes please! I restarted and encountered the aforementioned firmware update issue.
I then tried to turn it on a few times and immediately connect power as soon as it got to the firmware update stage (plugging it in any time before this will also prevent it from booting, I’ve found). I did not disconnect power when the firmware update screen was on, only after force powering it off before the next attempt. I can’t tell you the exact sequence of what I did from memory, but at some point in this process it reached the state it’s in now - pressing the power button illuminates the button LED, with a black screen. Unlike the turn-on issue before, this happens regardless of whether power is connected. I also have to long-press the power button to force turn it off, rather than a single press.
I cannot access the BIOS or boot to a liveUSB.
I have tried resetting the mainboard by unplugging the battery, letting it sit for a few minutes, plugging in AC power (it blinked red/blue/red/blue/etc) and then reconnecting the battery. (it has no CMOS battery)
I’m worried the firmware got corrupted? The LED diagnostic sequence has blinked a few times (not sure if mashing Esc, F1 and F12 helped summon this) and has about 20 blinks instead of the 12/13 described online? Here is a video: https://files.catbox.moe/4hx3qy.mp4
I am pulling the SSD and moving to a backup computer so I can get things done, but the sooner I can get this fixed, the better.
No AI was used in formatting this description
