Issue 1:
Variable Refresh Rate is not working correctly on the Framework 13 Pro on Linux. When viewing videos, full screen, with Adaptive Sync set to Automatic or Always, the playback stutters on the integrated display.
Issue 2:
Additionally connecting to an external monitor Adaptive sync appears to do nothing, despite Adaptive Sync settings set to Always. I don’t know if the external monitor issue is an incompatibility between Intel graphics and Freesync monitors.
I also have a FW 13 with a 7640U main board running the same distro and kernel as my FW13 Pro. The FW13(7640U) does not have the same issue when plugged into an external monitors.
- Framework 13 Pro (Intel Core Ultra 5 325)
- OS: Fedora 44 KDE Plasma 6.7.5
- Kernel: 7.2.8-200.fc44.x86_64
Screenshot:
What connectors are you using for the external monitor? Is this USB-C on the laptop side directly to USB-C on the monitor side, with a video-compatible USB-C cable?
Which port are you using on the FW 13 Pro? The rear two have a higher bandwidth capability than the front two, so if you’re using USB-C, it’s worth using the rear ports instead of the front ones.
Would you show a screenshot for your Display configuration? I am not familiar with VRR. It may help to show readers where this is configured, and what it is called in Fedora.
Both Laptops (FW13 and FW13 Pro): Using the rear ports on both laptops, expansion card: Type-C, Monitor: is a MSI MAG 272UP X24, cable: C-C 40Gbps 240W. I can add a screenshot I just don’t know if that would confuse people more or less, as it is literally just a drop down box in KDEs Display configuration.
For issue 1, might be related to this: VRR on Framework 13 Pro capped to 70fps when enabled on Linux
The 70fps limit basically felt like unbearable stuttering when navigating the desktop.
For external monitor support - what was the resolution you were trying to use? Intel hasn’t yet implemented proper hdmi 2.1 support (there’s an ongoing patchset for this), so if you were trying to do a resolution / refresh rate / vrr / etc. that requires hdmi 2.1 it wouldn’t work. If you are trying to use displayport instead, then afaik it should work - that I’m not sure why it would break (I’ve managed to diagnose a lot of this stuff, and even successfully patch my kernel to support new functionality by just leveraging codex - any of the other AIs should be capable enough to help too - so it may be worth trying it out if you have a subscription, but ideally framework and intel fix these issues themselves).
yes, I remember seeing that post about the 70fps cap. Very strange behavior, especially since VRR is not some sort of new technology.
As for the external monitor it has a Type-C port that supports DisplayPort Alt mode. That’s what I was using since I’ve never had this issue using that port with my other Linux PCs. With that said those other PCs are AMD based.
As far as I know, dp alt mode should work, it wouldn’t go through the hdmi 2.1 path (though worth double checking if the monitor is showing up as hdmi or display port).
The 70fps thing is an issue in the Intel driver - I put it in my reply in the channel, but they have a patch merged 2 weeks ago that solves it (I applied the patch on my machine and the issue went away), so you would get an update on a more recent kernel or you can run a patched kernel until it’s released/back ported to your distro.
That’s awesome news I’ll be patient then.
Kernel 7.2.10 seems to have fixed the stuttering problem (Issue 1). No stutter, but I can’t actually check the integrated displays current VRR Hz output, because I don’t know how to on an integrated laptop display, but I believe it’s working now.
With the new kernel update there is occasional display flicker whether VRR is set to on or not.
Issue 2 still stands as a problem.
