Does anyone know how the webcam and mic modules work when it comes to their switches?
I can see in my OS that when the webcam is switched off, an output is displayed showing you to switch the switch. That means somewhere there’s data being sent from the camera module.
I know this question has been asked before, but it’s all been about the original 13, rather than the pro. Have there been any changes?
I want to be certain that when the switches are set to ‘off’ that the mic and webcam are REALLY off, without any power to the sensor whatsoever. Similarly, I want to be sure that when the webcam is sending data, the indicator light MUST be on.
For the camera, this could easily be dealt with by providing a PHYSICAL privacy shutter made out of a material that cannot be transparent under IR light (such as aluminum). I really wish that framework had included that as an option. I personally have a hard time trusting a switch when the sensor itself is still visible.
When I switch my camera to the off position, my Cheese app shows a slider reminder, which is effectively a still bitmap image streamed to the video source. I assume it will work in all video-consuming apps.
How this is done I am not sure. It could be in laptop firmware, but I should think it would be more technically practical for the camera to do it, and if that is so, the camera would have to be powered on. I think you could log a ticket and ask a question - they should be able to speak to the hardware team on your behalf.
If you want a nice workaround, get a page binder from a stationer - it is a thin bit of plastic into which one can stuff around 40 A4 pages (example). It opens from 1mm to maybe 8mm. You should be able to slide that onto the top of the laptop, and since it is soft plastic, it won’t do any damage (just make sure the pinch point is not on the screen, of course).
I appreciate the reply. I may submit a ticket to see if the hardware team can answer it.
The page binder idea, while useful, I don’t think would serve my purposes. Infrared light, which most camera sensors can pick up, sees through some plastics. You need a significantly thick, or significantly dense material (like aluminium) to block IR and prevent any light from reaching the sensor.
Ideally, a solution could be provided that is physical but also as low profile as the current device, considering the bezel can be swapped out. It is possible to make a bezel that has a physical built in cover.
In the first generation webcam module (which is no longer available, but may appear as a refurb here), the webcam switch physically cut power to the device. It would drop off the USB bus, which you could observe in Device Manager (Windows) or in kernel logs / the output of lsusb (Linux).
The 2nd generation module does not do that, but still reportedly cuts power to the sensor and the camera controller chip substitutes in a preloaded “slider off” image.
The announcement notes a couple reasons why they made the change:
The privacy switch behavior on the camera also uses a new mode where instead of powering off the full camera, it cuts off the image sensor power and generates a placeholder blank image in the camera controller. This results in better behavior in applications and faster privacy mode switching.
(It is believable that applications reacted poorly to the entire webcam device disappearing on them.)
Fair enough. My only worry with aluminium is that it has a much greater ability to scratch delicate surfaces. I wonder if you could get a binder, and then glue some baking foil to the inside of it? Could that be sufficient thickness?
Ah, another thought: if a camera has IR capability, could you not switch it to IR mode to see what it can pick up when it is operating? If your blocking material works when the camera is actually on, I assume it will work when the camera is isolated.
If security is the utmost concern removing the whole module itself is an option. Government devices in secure facilities have certain components specifically removed so there is no chance of them being activated or used when they are not allowed to.
Someone could probably make a 3D printed bezel frame with a little slide slot, then a thin piece of acetate with AL could be slid into place to block the camera if that is the priority.
Or do what the some government agencies has been shown to do which is used black 3M electrical tape and just tape over them, unpeeling when needed.
The 1st gen module should work just fine too if the OP wants to swap theirs out and that does actually cut power to the device. Someone would probably agree to swap modules on the Framework Marketplace if it came to it too.
Looks like in @DHowett 's message he said if does cut power to the sensor but still leaves power to the module.
I did see earlier today someone had a 1st Gen module for sale on eBay. Looks like they updated theirs from v1 to v2 and we’re selling the previous gen.
Keeping controller connected and hardware cut off of the camera chip seems like a great solution to me. I hope the design is robust enough to not give attacker any chance even with firmware modification.
My question is can I upload my custom image to the controller? The default is good for people to figure out that they need to flip the switch. But it tells unnecessary details about my laptop in case I switch it during the call for example. Feel free to make feature request of it.
I think you will find the camera has an IR rejection filter on it - this is common on semiconductor cameras because IR causes the camera colour balance to go off.
It would be easy to check if the camera has any IR sensitivity - point a TV remote at the camera while checking a suitable program where you can watch the camera output to see if the the camera spots any IR output from the remote.
If the OP still wants to block the camera physically then the same test will verify the IR opacity of any material used to cover the camera.
I happily defer to your expertise! My thought process was to respond to the OP’s worry that plastic would be insufficient as a blocking material. I find that possibility somewhat implausible to be honest, but if someone is worried about that, there is no harm in considering how to handle it.
I have an even more implausible theory, but I put it here for entertainment: a camera has nefarious IR-sensitive modes that are not normally user-accessible. If it is true that such a camera could defeat a plastic cover, then an aluminium clip-on may be a good approach.
Some plastics and paints are definitely IR transparent. A work colleague I once had reckoned that black paint was made black by making it transparent at either IR or UV, and you could work out which. If the paint had a vaguely reddish hue when reflecting sunlight then it was transparent at IR, if it had a bluish hue then it was transparent at UV. Now I’m only going on his theory, and have not had a chance to teat it at all. However in support of his theory when it comes to plastics, note that the IR window on a TV remote tends to be a dark red plastic, which is almost black at visible light, but quite transparent at IR. But when it comes to blocking IR if the plastic was green or blue I suspect it will block IR - but again, the test is simple.
If the test needs any other confirmation then use a RPi with a NoIR camera, which is missing the IR filter so it can ‘see in the dark’.
