INSTALLATION
When receiving my Framework 13 Pro Intel X7 358H, I installed NixOS 26.05 using this guide.
lspci -nnk | grep -A 3 -i net
00:14.3 Network controller [0280]: Intel Corporation Core Ultra Processors (Series 3) CNVi Wi-Fi [8086:e440] (rev 01)
Subsystem: Intel Corporation Wi-Fi 7 BE211 320MHz [8086:0114]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
dmesg:
[ 6.329203] iwlwifi 0000:00:14.3: Detected crf-id 0x1002a10, cnv-id 0x80a00 wfpm id 0x80005b20
[ 6.329229] iwlwifi 0000:00:14.3: PCI dev e440/0114, rev=0x480, rfid=0x20113100
[ 6.329234] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE211 320MHz
[ 6.341194] iwlwifi 0000:00:14.3: loaded firmware version 106.c88d33af.0 sc-a0-wh-b0-c106.ucode op_mode iwlmld
[ 7.002618] iwlwifi 0000:00:14.3: Detected RF WH, rfid=0x20113100
[ 7.172899] WARNING: net/wireless/nl80211.c:10577 at nl80211_get_reg_do+0x22a/0x270 [cfg80211], CPU#1: iwd/1120
[ 140.012189] warning: `Socket Thread' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
This is my flake.nix:
inputs = {
nixpkgs.url = "github:NixOS/nixpkgs/nixos-unstable";
nixos-hardware.url = "github:NixOS/nixos-hardware/master";
outputs = { self, nixpkgs, nixos-hardware, ... }: {
nixosConfigurations.fw = nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
./configuration.nix
nixos-hardware.nixosModules.framework-intel-core-ultra-series3
hardware-configuration.nix:
{ config, lib, pkgs, modulesPath, ... }:
imports =
[ (modulesPath + "/installer/scan/not-detected.nix")
boot.initrd.availableKernelModules = [ "xhci_pci" "thunderbolt" "nvme" "usb_storage" "sd_mod" ];
boot.initrd.kernelModules = [ ];
boot.kernelModules = [ "kvm-intel" ];
boot.extraModulePackages = [ ];
fileSystems."/" =
{ device = "UUID=b30e528f-23d8-4b23-91d3-185e78c79b6a";
fsType = "bcachefs";
fileSystems."/boot" =
{ device = "/dev/disk/by-uuid/2092-DE59";
fsType = "vfat";
options = [ "fmask=0077" "dmask=0077" ];
swapDevices = [ ];
nixpkgs.hostPlatform = lib.mkDefault "x86_64-linux";
hardware.cpu.intel.npu.enable = true;
hardware.cpu.intel.updateMicrocode = lib.mkDefault config.hardware.enableRedistributableFirmware;
hardware.bluetooth.enable = true;
Upon installation I only had this line added to configuration.nix:
services.fwupd.enable = true;
networking.networkmanager.enable = true;
I also updated the firmware using fwupdmgr
This is my kernel version:
Linux fw 7.2.10 #1-NixOS
PROBLEM
Out of the box WiFi was pretty bad, in KDE Plasma 6 I see a signal strength of 57% although the access point is 5 meters away. Every other wireless device in the house works great.
I encounter hickups where the wifi seems connected but I have no internet connection.
TRIED THESE OPTIONS
So with some searching online I tried out a few more options but none of these help to address the wifi issue:
networking.networkmanager.wifi.backend = "iwd";
networking.networkmanager.wifi.powersave = false;
networking.wireless.iwd.enable = true;
hardware.enableRedistributableFirmware = true;
Any people with this hardware experiencing the same issue on NixOS or other distributions?
What else can I try?
