FW 16 AMD 7040, soft issue? (W11 Pro 25H2, programming use)
Hello Framework community, sharing my recent issues with the Framework 16 where I’m pointing more towards a software than a hardware issue
  • Which OS (Operating System)?
  • Windows
  • Which release of your OS (Operating System / Windows 10, 11)? (if you are having a Linux related issue, please create your thread under the Linux subcategory)
  • Windows 11 Professional 25H2
  • Which Framework product (Laptop 13, Laptop 16, Laptop 12 or Desktop) and which generation of CPU (Intel 11th gen, Intel 12th gen , Intel 13th gen, Intel Ultra Series 1, Chromebook, AMD 7040 Series, AMD AI 300 Series, AMD AI Max 300 Series) or GPU (NVIDIA® GeForce RTX™ 5070, AMD Radeon™ RX 7700S)
  • Framework laptop 16 AMD 7040 series without graphics module (running the AMD iGPU)
As for what softwares I run I’m using Docker desktop (4.91.0), IntelliJ Idea EAP (2026.2 I believe), Hermes Desktop (v0.21.3), Ollama running in background (0.35.1)
As for devices only the charger and an HDMI cable are linked to my laptop with another ultra wide screen display (none issues)
How I use my Framework laptop recently it’s for programming and I have ordered it for both programming and personal usage (some game, was expecting new graphics module and was planning to get one someday)
I have both Windows and some Fedora 4X version also installed on two different storage devices, not running dual boot (I didn’t know how to back then and mostly using Windows)
I think it’s been two years and I have enjoyed and still enjoy the product without any dealbreaker issues until these two or three days
My computer still runs Windows, battery gets charged and the OS still responding because I can remotely control with TeamViewer installed but my main issue is that recently my mouse and my keyboard seem not to work at some point and one time rebooting did not solve it so I shut it down with the “sleep” button (finger scan seems not affected)
Opening my apps also with a browser (Firefox) works fine with the keyboard and touchpad and running some Docker containers + some local webserver seem to be the way to reproduce the issue (through configurations on IntelliJ Idea EAP)
Writing this post on my phone, at one moment I left my laptop untouched and it seemed to respond again but playing with the Idea interface killed it so I’m suggesting a software issue here
Rebooting and using the F11 or F12 + delete keys get me to the boot menu and the keyboard works fine
Did not do any unplugging, unscrew or disassembly so far
Thanks for the help, can provide more information if needed
Is the issue only happening when booted into Windows? Have you tested to see if usage drops in Fedora?
Cannot confirm if I have the same issue under Fedora. Right now my quick and dirty way to fix it is to work only on the main screen and leaving my other monitor (high and wide resolution) off with the HDMI cable unplugged
My touchpad and keyboard seem to be working with some moments where they gone and after waiting a few moments I can use them back again
I need some time to set things up within Fedora and test the laptop’s behavior
I would consider plugging in an external keyboard and mouse - maybe your input fascia has a connection problem affecting both devices. You may have to wait for the problem to be re-exhibited, of course.
Still working on Windows currently, I’ve opened the same apps as usual, nothing big running in background, no virtual container or anything
Just typing text and for two or three times, keyboard and touchpad stuck but working again after waiting a few seconds and I decided to plug a mouse when I realized I was going nowhere with them both not responding
It seems to do the trick, everything seems to work fine but I’ll keep the post updated as long as I see the issue repeating itself
