FW12 Batch 9 Guild
I got my tracking number but when i click the link to track it i get this error: “This carrier’s shipments can’t be tracked right now. Please try again later”
Has anyone gotten that issue?
Mine arrived, now its time to install arch : D.
I will keep an eye out for cracking, so far nothing.
Yes. I had that just after I got the notification that it was ready to be shipped. Then a little later I found it could be tracked.
Just checked. It’s working now! Was worried for a sec lol. Mine landed in Japan at night, so I guess we’ll see how long it takes from there.
At first mine was set to arrive tomorrow, but it ended up arriving today. It was quite a fast delivery all things considered.
Speaking of, it arrived and I just finished putting it together :smiley: Installed Fedora. Got Windows has spoiled me…First popup on Fedora and I feel a flash of entitled anger at having to Do Stuff Other Than Just Press Install. This’ll be the first time I’ve tried to use a Linux distro as any sort of daily driver, so…We’ll see.
Linux takes a bit of getting used to, but after a while you’ll be like my and want to punch anything else. I love all the Linuxes…NixOS is my current favorite though because of the reproducible configurations.
NixOS is my favorite too for a lot of reasons, but it’s not exactly a distro for someone brand new to linux lol.
It gets easier! Fedora has a lot of guides and FW offers staff guides for it too which should make the experience a lot easier!
Yes, absolutely correct. Do not pick NixOS as a beginner. I like to recommend Mint or ElementaryOS for folks completely new to Linux. Then Ubuntu or Fedora. Then we can get into the Arches and NixOS and things like that.
I think for Framework specifically, anything that is Ubuntu or Fedora based that doesn’t deviate too far from the standard release will work fine for beginners because FW offers staff support and lots of guides around. Mint I’d say is the best for beginners although Cinnamon’s touch support is hit or miss. I really like Fedora Silverblue as a beginner distro as well since it’s atomic and immutable; it’s very difficult to brick. but i’m not sure if that counts for Fedora support since it’s set up differently than stock Fedora.
If you’re just using the 12 as a kind of office/school laptop then you can’t go wrong with just stock Ubuntu with Gnome, and then keeping most of your apps as Flatpaks and snaps. Same with stock Fedora with gnome. Once you get into more specific needs then the conversation expands greatly imo.
But for Nix, i’ll be set up to test different environments with the 12 (hopefully tomorrow if my tracking is accurate). Also i feel like most people don’t even need to get into Arch and NixOS if they don’t need to lmao. They’re very geared towards DevOps kind of work where you either want the latest packages or want everyone on the same builds, sometimes sys-admins for Nix too if you need to manage a ton of machines (which is what i’m studying now), but other than that it’s more preferential or based on freedom/uniqueness. I certainly have no use case for Gentoo even though that is by far the most “free” (as in freedom) distro out there.
Just put my sage together. What a perfect computer for a lap, as all laptops ought to be. Hurrah!
Mine says tomorrow. So stoked!
Got my sage running with nixos with KDE plasma. Solid experience so far.
How is the touchscreen for Plasma on Nix? I get mine tomorrow (assumingly) and I plan on using several DE’s/WM’s for testing but i’d like a foundational “stable-out-of-the-box” DE for touch, which is either Gnome or KDE.
I ended up going with Fedora Plasma :smiley: …I don’t know if that’s the same plasma you’re talking about though. I also don’t know what Nix is.
I also installed Windows 11 on the removable storage port square 250GB thingy I got with it, which was a bit of a pain but it seems functional. That said, the extra storage seems to get toasty even when I’m not actively transferring data and it’s a bit of a pain to swap out ports…I haven’t been able to remove it with just a finger yet, I’ve had to use the screwdriver’s edge side to push it out.
It’s the same desktop environment, but different distro. Also nw about not knowing about Nix. It’s kind of a niche thing for nerds (me being one of them).
Yeah the removable storage is still technically external, so it doesn’t have the same thermals as the nvme. Windows 11 especially is a very heavy OS, adding to the heat. Since you’ve committed to Windows on that drive, i’d recommend keeping windows sessions short or getting a laptop fan to cool the drive down a bit.
It may be better to dual boot Windows on the main drive, but I read a bit and it sounds like just a pain to do that - I think I’d have to uninstall Fedora, install Windows base, then install the Linux distro I want? Ugh.
I don’t plan on doing anything with the Windows 11 external beyond email and teams, though, so it might be okay. Maybe? Will it? I don’t have xp using Windows on an external - will the heat get high enough to be an issue if I’m not playing games on it? :thinking:
Dual booting might be annoying for beginners but there’s lots of guides on it out there. Generally Windows should be installed first, since it’s very finnicky when it comes to its sizing, it usually requests the entire disk (I think? I’ve only installed windows 11 home/pro, not sure how server does it, which i doubt you bought lol).
As far as heat goes. The worst case scenario is you fry your drive from overheating, which is money wasted. It’s likely that if you can keep it cool with a pad that it might be fine if all you use it for is browser work, but i’m not sure how well FW’s external drives are.
Edit: you could also manually set up Fedora first with exact size you want in the installer, then try and let windows fill in the rest of the gap. not sure which is easier. but just make sure you use os-prober and ensure Grub can find Windows otherwise it will be an issue. But yeah i’d reccomend a youtube guide on it. There’s a lot out there. and even if you can’t find one for Fedora, the principles tend to be the same.
I haven’t gotten virtual keyboard working yet. Haven’t put too much effort into it. But otherwise it works pretty good!
