FW13 Pro Batch 14 Guild
Aw man, I haven’t even gotten the shipping email or a tracking number yet XD
Well I am still setting it up with cachyos. But it is really a nice device. Keyboard feels a bit strange in the first few minutes, but like it much now.
Only thing I have, the games I tested did not run. (I run cachy with steam on some machine, none had any issues until now). But I’ll investigate tomorrow or later… :wink:
I got mine yesterday as well. Running Fedora 45 beta to see if it has any hardware issue, Everything works as expected. Tomtoc 360° laptop sleeve (13.5-14 for surface laptop one, not the one for mac) fits perfectly.
The only concern I have is Framework 13 pro seems not as rugged as my old (> 10ys) Thinkpads. It needs some gentle treatments.
Update 2026-10-30
I encountered a power on problem after day 1. I was using my 13 pro on a commuter train and put it into sleep when I was about to take off from the train about 7AM local time. When I tried to test some VDI related settings using my 13 pro around 11AM, it no only didn’t wake up, it even didn’t power on. Right-side LED showed no signal at all when the power supply was plugged in, power button also showed no light at all. I searched the forum and found someone encountered a similar issue but solved it by reconnect the battery connector, I followed similar steps and got the power-on issue solved.
Apparently I need to test many things in these coming 28 days.
Set mine up yesterday with fedora 44, will move to 45 in a month or so.
I am really very happy with the laptop, no problems so far. I have it here next to my ThinkPad T14s gen 6 (modern, almost a year old). Screen and trackpad are better on the framework. Possibly it’s a little less rugged, but that’s okay with me. Put a lovely M2 skin on the lid, it looks gorgeous. And I like the smoke black framework sleeve too.
Coming from the Framework12 I have some first impressions about the new device…
I am very happy with the device at all. The build quality is really nice. The FW12 makes a cheap impression. The FW13P is the whole other direction.
I can’t get used to fracional scaling, but that’s not an issues with the device, but with modern times, and bad implementations (Wayland, X11, Wine don’t work well together with fractional scaling).
The hinge is sturdy but easy to open also. I like it.
The touchpad feels really nice until now. Much better than the cheap FW12 touchpad. I had some trouble with gestures in Plasma on cachyos, but as I switched from Gnome to Plasma it might be unrelated to the touchpad itself.
I really like the 120Hz display. Until I got the device I thought no one would need 120Hz. Now I don’t want to miss it :slight_smile: It all looks so smooth. But this seems to be a problem for some games.
Pine crashed soon after starting the game. I could resolve it by lowering the frequency to 60Hz and resolved it with gamescope, forcing 60Hz.
World of Warcraft ran in fullscreen, but on top of plasmas bottom-bar. It also did not get the whole height to setup in WoW. I also resolved it with gamescope, forcing fullscreen over the whole screen resolution.
Another game flickered between the desktop and the game. Could be resolved by switching back to the desktop and again back to the game. Could also be resolved with gamescope.
Brighness of the screen is really nice. Had the FW12 running at 30% (to save battery) and it was… OK. The 13P on 30% has perfect bightness to me.
Speaking about the battery… I was impressed about the long estimated running time. When I started a game it dropped dramatically, but that was to be expected. Running with low demands it’s really really long (the FW12 was nearly always using fans, got warm and had little time on battery). But yesterday evening I closed the lid of my fw13p with around 60% and this morning I opened it with 11% battery. Something seems to go wrong here… I’ll have to investigate…
Ah, the finish is really nice, but it really gets fingerprints and noseprints of the dog very quickly.
On normal, non demanding usage, it is totally quiet and not very warm.
Keyboard felt a little strange at the beginning, but after one day I started loving it. Way better than the really bad and cheap FW12-keyboard and even better than my Thinkpad x13 G4. I can type really fast and with little failures.
Thx for your feedback. What about the expension cards? Is everything fine?
To be honest I haven’t tested all. :slight_smile:
USB-C and USB-A are working as expected. USB-A is really tight. I had to use some force to insert and to remove my USB-device. But feels sturdy.
The expansion-cards themselves sit tight, but not too tight. I like it.
As the expansion cards are all the same, the one issue I did not like with the FW12 happens here also. The USB-A ports are not as “deep” as they are on other notebooks, meaning when I insert my really small Nitrokey it does not fit completely into the port. That is a bit annoying… (Details here: Placement of the USB-A-socket in the expansion-card)
P.S.: Do not game on the couch! It’s getting really, really (!) hot :fire: and needs the intake at the bottom :wink:. But it cools down very fast also.
P.P.S: The FW12 has it’s power-button with the power-indicator at the side, so you can see if the device is sleeping when the lid is closed. On the Thinkpad you can see iff the device is sleeping with the little red dot in the ThinkPad-Logo in the display. Ob my new FW13P I don’t know if its really sleeping or not.
I’m a little confused about this too. Mine went straight from Kansai to Memphis (times are in CST). Could be that they partitioned the batches by region (now that I see, as you said).
Fellow batch 14 here, was part of the 10% that didn’t get their emails with the rest of the batch. Finally got it last week, then got the tracking on Thursday.
and now its stuck in customs.. sigh
Does anyone know how long it takes to clear US customs? Its been about a day now.
I received the laptop a couple of days ago. I set it up with Fedora 45 Silverblue. Other than one issue where the fingerprint sensor wasn’t available to use (fixed by enabling the feature in authselect), everything has been very smooth so far.
I turned off “Automatic Screen Brightness” in the Power Saving Options - it’d cause the screen brightness to fluctuate wildly during use, and to me, the brightness level too high with the setting on.
Great machine overall. Suspend works well, and battery life looks good - it may not match the m2 macbook air I’m coming from, but I’m very happy to be back on linux again.
